New boat, a couple of questions
  • chief351
    • Aug 2007
    • 107
    • Ontario
    • 2015 SN200 ZR409
    Bought a 2005 SN 196 last week! Some questions:
    FCC: Wondering if this WIX filter can be used instead of the PCM filter which sells for ~$35.
    http://www.fleetfilter.com/filter/wi...ers/33436.html
    I can buy the WIX locally for cheap. The PCM filter is considerably more expensive and I would have to have it shipped to Canada which makes it even more expensive.
    My 2nd question is in regards to changing the transmission fluid. On my 1990 SN I was able to use a transfer pump that had a about a 1/2 inch tube attached, it worked great. On my 2005 I don't see how my transfer pump will pull anything out of the transmission. The fluid registers correctly on the dipstick but I can't actually see the fluid. Do I need to get a transfer pump with a very thin extractor tube?
    Thanks in advance
    New ride 2005 SN 196
    Sold 2010-09-05 - 1990 SN - 610 hrs
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    For the second question, you need to build one of these:
    search my posts for more about it and tranny fluid changes.
    • chief351
      • Aug 2007
      • 107
      • Ontario
      • 2015 SN200 ZR409
      Thanks AirTool. Just made one with stuff I had in the garage!
      I am curious about the WIX filter. I have used WIX in numerous applications over the years and they have never let me down. I don't know why this water/fuel separator would be any different.
      • teamseal
        • Dec 2006
        • 412
        • Panama city, Florida.
        • 2008 196, 1992 Shamrock 20' center console, 1965 Rickshaw race boat, 2017 ski 200 H6.
        Chief,
        The PCM filter needs to "clip" to the bottom flange of the high pressure pump Via a o-ring type grommet and also fit snug in side of the FCC. If the Wix does that then try it out and let us know how it works. Other wise I think I would stay with the PCM FCC filter for a little bit of up cost.
        • teamseal
          • Dec 2006
          • 412
          Wow that was strange!
          • chief351
            • Aug 2007
            • 107
            • Ontario
            • 2015 SN200 ZR409
            Thanks a lot teamseal. I will check it out when I head back to the cottage in 2 weeks!
