The problem is when it gets to operating temperature the engine missfires and loses power when the rpm is increased above 2000rpm,the more the rpm inreases from there the more the engine surges and misses and it also has a bad knocking noise which sound like pre-ignition.[i have checked the base timing and maximum advance when the problem is occuring and they are all within specification.
I have followed procedures to test for any fault codes recorded in ECU and there are not any recordings.
i am conserned about the hydralic lifters as i have checked the hydraulic lifter adjustment to make sure they are not to tight.[the lifters do seem inconsistant to adjust as this has been adjusted with shims on 3 occasions, but has never made any difference with the problem.
I have tested the engine management system and fuel system and cannot find any faults.
