I know this is an old thread, but I just found the problem for my situation. apparently the 60 amp breaker was intermittently tripping and reseting at high RPM's for some reason. I went to start it up to start on the diagnostics and noticed that the fuel pumps weren't running, so I checked the relays (which were fine) and then checked the breaker. When I reset the breaker the pumps would run for a few seconds (just like normal) and then I noticed that if I hit the reset button they would run again... so I tried running it while I had my girlfriend hold the reset in and it ran almost perfectly. So I bypassed the breaker (put all the wires on one post) and took it to the lake for a test drive and it ran perfectly.
I had already installed a battery isolator, so the current from the alternator doesn't even run to the breaker anymore. I also had a problem with the dash loosing power last year, which I assumed was due to not having the alternator tied into the breaker, so I also rewired the power supply to the ignition/dash (and changed to dual supply setup so I could run half of the toggles on the accessory battery and the other half on the starting battery). Let me tell you - the electrical wiring was shoddy at best and not very robust, it looked like someone told a middle school kid where things should be connected and let them figure out how to do it.
So at this point, the boat runs perfectly. Im not exactly sure what is running through the 60 amp breaker anymore because I didn't feel like cutting open the wiring hanes (and all the wiring diagrams were a little too vague) so I would probably be fine bypassing the breaker, but I'm ordering a new one just to be on the safe side.
