2006 ZR6 Overheating
  • NicksNautique's
    • Jun 2009
    • 16
    • NORTHERN IRELAND
    • 2006 S.A.N. 210 TE 1997 SKI 196
    Hey guys, just had a great day on the water when my ZR6 flashed an engine too hot warning.
    I have a closed cooling system fitted, i topped up the coolant reservoir and check for any leaks and couldnt find any.
    In idle the boat will overheat but remains cool when running above 1000rpm.
    I havent checked the impeller yet.
    Immediately after running i checked the coolant reservoir and when i removed the lid the coolant seemed to have lost of air bubbles in it.
    Any thoughts??
    2006 210 Team
    • 16871
    Very likely it is the impeller. Even though you have closed cooling, the raw water cools the heat exchanger. If the impeller is damaged, this cooling water will be restricted.
    • HS
      • Oct 2007
      • 1333
      • Sammamish, WA
      • 2010 SANTE 210 (Sold)
      Fresh Water Flush?
      FWIW: If it has Fresh Water Flush, check for a loose cap -- This has not happened to me but somebody once mentioned to me that if the cap is not tight it could cause an overheat...
      • wskiboy
        • May 2010
        • 50
        • canada
        • 1996 196 closed bow
        check your o ring on your sea strainer . i was missing mine,and my boat kept overheating .
        • NicksNautique's
          • Jun 2009
          • 16
          • NORTHERN IRELAND
          Thanks guys i will get a chance to check it all out on Wednesday, then i will check back in and let you know.
          • NicksNautique's
            • Jun 2009
            • 16
            • NORTHERN IRELAND
            Fixed??
            OK got impeller changed out, also checked the strainer backet elbows and found they were very loose. taped them up and reattached them. Also checked all the hoses for air leaks etc. Had a little water on manifolds so i nipped them down a bit tighter. Other than that its a water test later to see what happens next!!!
            Thanks for all advice so far!!
            • ers906
              • Feb 2010
              • 921
              • Phoenix AZ
              Just to clarify for my own knowledge, there is a raw water intake in a closed cooling system?
              Eric, Phoenix AZ
              G23 550 hp (finally here)
              2002 Super Air
              • j2nh
                • Dec 2003
                • 628
                • Spread Eagle Wisconsin
                Yes there is. Raw water is taken in through the same place it would be taken in if a boat did not have closed cooling. Raw water is required to:
                Exchange heat with the closed loop (antifreeze) cooling system
                and
                add water to the exhaust manifolds to cool the exhaust system of the boat.
                If you did not have this open water system the engine would overheat because of no energy transfer away from the antifreeze and your exhaust system would melt. Not sure which would happen first.
                NicksNautique's, that impeller doesn't look that bad and shouldn't have given you an overheat alarm. I think you may have found the problem with the elbows. Any air leak on the suction side will mess things up.
                2018 200 Team H6
                2009 196 Team ZR 409
                2005 196 Limited ZR 375
                2003 196 Limited Excalibur
                1999 196 Masters Edition
                1987 ProStar 190
                • NicksNautique's
                  • Jun 2009
                  • 16
                  • NORTHERN IRELAND
                  Ok i'm hoping the water test goes to plan.
                  Thanks
                  Nick
                  • teamseal
                    • Dec 2006
                    • 393
                    • Panama city, Florida.
                    • 2009 196 ZR-6
                    Dont be afraid to change the impeller once a year on a ZR-6 motor as it is a PITA to get all the rubber parts and re-burp/purg the system once the coolant has been blown out especially on the cat motors.
                    Make sure the gasket is in place on your water filter, I recieved a call over the weekend of a guy that threw his gasket overboard when he cleaned the cup and strainer screen and he did not notice it gone when he reassembled it.. Overheated right now!!!
                    • j2nh
                      • Dec 2003
                      • 628
                      Spot on from TeamSeal.
                      Impeller is cheap, lost day on the water is priceless. Change it every year and keep a spare in the boat. Same for that stupid gasket on the strainer. I know of two people who have lost theirs cleaning the cup and dumping the gasket in the lake. Get a spare, keep it in the boat.
                      2018 200 Team H6
                      1987 ProStar 190
                      • NicksNautique's
                        • Jun 2009
                        • 16
                        • NORTHERN IRELAND
                        Seems to be going good!!
                        Ok guys running temp 159-168 on average for 2 hours tonight. Everything seems stable.
                        Thanks for all your input so far. I do think i have a loss of coolant, though only on a small scale. Any suggestions of where to start the faultfind??
                        Thanks!
                        • NicksNautique's
                          • Jun 2009
                          • 16
                          • NORTHERN IRELAND
                          Guy's i'm on a roll found that too and got it fixed up!!!
                          Boat is back to normal.....
                          Love it...
                          • wskiboy
                            • May 2010
                            • 50
                            • canada
                            i am glad you fixed your problems . i have been told and have noticed that everytime i top up the resevoir and next time i check it the level down about one inch then i would fill it back up down one inch i dont know where it goes . now i dont fill it right to the top and have had no level change all season . ski-on
