Short dry run
  • RexB
    • Oct 2009
    • 74
    • Sacramento, CA
    Short dry run
    After a great ski day, we trailered the boat out of the water. My buddy sitting in the driver's seat had a brain fart and left the motor running while I pulled it up the ramp. When I stopped, I heard the motor and shouted for him to turn it off. He did. Total time, probably 30-45 seconds, engine temp was still around 175. Any damage likely?
    The boat now has 20 hours, so I'm taking it in for an oil change and some minor warranty work. I'll ask them to look at the impeller. Anything else I should have them check?
    2009 211 Crossover; Triple White
    "I used to be disgusted; now I try to be amused...."
    E. Costello, 1979.
  • eseybold
    • Apr 2008
    • 60
    ...................unlikely to cause damage but I would proabably change the impellar because if the impellar got hot and it breaks down prematurely it could be costly to other parts of your engine down the road. Your boat is so new you want to protect the investment. Beyond a possibly worn impellar there should be no damage.
      The impeller could be OK, or not. The problem is if it is bad, or slightly damaged, it could possibly fail when you are away from the dock, nowhere near your trailer.
      This could be anything from a minor inconvenience, to a major safety issue, for example you need to get off the water in a hurry because of a thunderstorm.
      Get it changed when you take the boat in for service.
      • migs
        • Aug 2008
        • 707
        • San Mateo, CA
        • SAN 210 TE
        change that impellar no matter what.
        Migs
        G21 - En route
        SAN 210 TE (Finally)
        06 Sky Supreme V220(previous)
        05 Sanger V210(previous)
        01 MC X1(previous)
        99 Air Warrior(previous)
