Confused about engines - Is a 5.8 Pro Boss = GT40
  • Sandro
    • Jan 2012
    • 37
    • Tbilisi, Georgia
    • Ski Nautique 176, 1994 Ski Nautique 206, 2008
    Im trying to get the service manual of my engine. Ive asked www.correctcraft.com to send it to me. My engine experiencing some problems with high RPM, which is described here: http://www.planetnautique.com/vb3/sh...24448-High-RPM
    If you have any ideas about this technical issue, please let me know.
    Thanks
    • swc5150
      • 2240
      • Eau Claire, WI
      • MasterCraft Prostar
      You may want to PM Jody Seal on this issue, to see if he has any insight? It sounds similar to the early incarnations of the GT-40 ('97 versions), that tend to race before settling to idle. To solve this, a newer ECM will solve the problem. I'm not sure there is an updated ECM to solve your issue? You do have one of the earliest versions of PCM EFI, and quite a bit of tweaking was done in subsequent years to truly get it "right". I hate to admit it, but MC/Indmar really forced the others to scramble back then.
      '08 196LE (previous)
      '07 196LE (previous)
      2 - '06 196SE's (previous)
      • Sandro
        • Jan 2012
        • 37
        • Tbilisi, Georgia
        Thanks a lot for you advice. I will contact Jody.
        • Sandro
          • Jan 2012
          • 37
          • Tbilisi, Georgia
          Originally posted by DanielC View Post
          If your engine has an intake manifold that looks like the manifold in the link above, you have a GT-40 engine.
          If your engine looks like it has a carburetor, it has throttle body fuel injection, and is NOT a GT-40.
          Here is how it looks like.:
          I think this is throttle body injection system and its is Pro Boss and not a GT40 right..?
          BTW I need a service manual for this engine. Do you have any link .?
          Thanks
          • mf01
            • Jun 2005
            • 515
            • Austin, TX
            This might have what you need: http://www.skidim.com/prodinfo.asp?number=L190140
            Previous:
            2011 Super Air Nautique 210
            1994 Sport Nautique
            • t.franscioni
              • Jun 2014
              • 715
              • United States
              • 2002 SANTE
              #21
              Looking for some knowledge on the 1993 Ford 351 offerings. According to the 93 PCM engine manual there were 2 versions of the Ford 351, a 240 hp and a 280hp version. Anyone know which one I have? All I know is it's a ford 351 carb with protec electronic ignition (no fuel injection). I have seen pictures of other 93 carb motors with a small square plastic engine hood that says PCM 5.8 on it. Others have this bigger plastic engine hood and say PCM 5.8 HO. Mine has the larger engine hood like the 5.8 HO but with a sticker that just says PCM power plus. Could be a 5.8 HO with just a replacement sticker? I see Nautique parts sells this exact sticker. What you guys think I got here?
              • Blamey
                • Sep 2015
                • 595
                • New York
                #22
                If you have the HO you'll have GT40s heads which have a three bar marking on them if you search you can find details on what exactly they look like.
                • t.franscioni
                  • Jun 2014
                  • 715
                  • United States
                  • 2002 SANTE
                  #23
                  Ok so for 1993 PCM had the Ford 351 WITH GT40 heads @ 280hp and WITHOUT GT40 heads @ 240hp? Did the plastic engine cover and sticker indicate this head difference then? Was that why I'm seeing the small square plastic cover and the larger engine cover? Looks like from
                  below pics the regular non HO 5.8 had the smaller square engine cover with regular distributor type ignition while the HO 5.8 had the protec electronic ignition with larger engine cover? Does this seem correct to assume?
                  • TRBenj
                    • May 2005
                    • 1683
                    • NWCT
                    #24
                    No. The larger shroud came over the protec ignition which was common on both standard and HO offerings.
                    Heads were the primary difference between them. The engine tag should tell you which you have, or the markings on the heads themselves.
                    1990 Ski Nautique
                    NWCT
                    • t.franscioni
                      • Jun 2014
                      • 715
                      • United States
                      • 2002 SANTE
                      #25
                      Ok thanks. That makes sense. So I have the larger shroud because I have the protect ignition and that larger shroud is used to cover the protect ignition components (I think that's what you meant by "shroud comes over protection ignition"). The shroud sticker I have just says PCM power plus and doesn't mention HO anywhere so I'm maybe I have the regular heads with protec ignition. So the 240hp motor not the 280. I'll check the heads when I get home. Thanks.
                      • t.franscioni
                        • Jun 2014
                        • 715
                        • United States
                        • 2002 SANTE
                        #26
                        Confirmed only 2 bar heads. So the PCM power plus sticker makes sence now. It's not a HO pro boss PCM Ford motor its the lesser hp 351. These were rated at 240hp? Thanks for the help, just wanting to understand what Iv got here. I understand the protec ignition can become problematic over time and need to be swapped out for a distributor type ignition system sold by skidim and NP. Looking at the protec I see it incorporates some safety features tied into oil pressure and water temp that I'm assuming activates the red alarm light on the dash in addition to limiting engine rpm. Are these alarm signals and reduced rpm lost when going to the replacement distributor type ignition?
                        • SusieStrunk
                          • Jul 2016
                          • 13
                          • Las Vegas/Orlando
                          • 1994 Ski Nautique (open bow)
                          #27
                          I have that engine
                          • Canuck-Surfer
                            • May 2019
                            • 181
                            • Ontario, Canada
                            • 08 Nautique SV211 96 Sport Nautique
                            #28
                            Originally posted by SusieStrunk View Post
                            I have that engine
                            I hate to reply to an old thread, but I have a follow up question to this thread. When did the problematic ProTec ignition end? I have a 1996 5.8 HO ProBoss (Sport Nautique). It should NOT have ProTec, correct?
                              • 17183
                              #29
                              Does it have a regular distributor with plug wires?
                              If so, no ProTec.
                              If not, well, you can always swap it out when (not if) it dies.
                              • Canuck-Surfer
                                • May 2019
                                • 181
                                • Ontario, Canada
                                #30
                                I only spend about 15 mins looking at the engine for the first time 2 weeks ago. The spark plug wires are missing. I don’t have a great zoomed out pic of the block but there is part of what looks like a white dizzy. See pics...
