Originally posted by Roscoef16
View Post
I would speculate that the reason the Paragon has less ballast than the prior G23 was because maximum weight of the Paragon would exceed safe limits with the prior ballast, full fuel, gear and max people on board. Nautique would not want the Paragon to be certified for fewer people than the G.
With a much heavier boat ballast probably had to be reduced. Reducing ballast was probably an easy decision because the surf wave was fantastic even with less ballast than the prior generation G.
Then when Nautique used that platform for the G it was "easier/cheaper/faster" to keep the same ballast configuration. Perhaps they will be motivated to fix this in future generation G boats. But it's not like being under ballasted is hurting G23 sales so don't hold your breath...
Sent from my SM-G986U using Tapatalk
I specifically asked the question on the Nautique owner Facebook page and found https://www.facebook.com/leland.suttonjr has done some experimenting with subfloor bags. He sent me a few pictures and there is in fact lots of room to piggy back off the stock bags.Originally posted by blufly View PostHi Greg - thanks for your thoughts on this as you clearly have exceptional pedigree in this area - this definitely puts my mind at ease knowing that im not goin to have to go to great lengths to slam it to get the ultimate result - but what im understanding is that the GEN3 simply just needs the old stock ballast setup of 2850 and it would be perfect -give or take a few lead bags- which would be perfect for my long haul application.
I have ordered it on a triple axle due to the regular travel distance so minimal lead will be fine i just didn't want rely on lead - So based on this Im stil wondering if there is room under the floor for the bigger bags ? clearly the GEN3 hull is massive has anyone got any build pics of the lower deck before the top skin goes on to see the construction layout compared to the old mould? as then all would stil run perfectly from a factory perspective without the added drama of filling locker bags for me
there must be a reason Nautique dropped the stock ballast and this is clearly an issue with the wave performance on the G
Amorin56 - Dude this is music to my ears
As this is by Far the best option IMO , I don't have facebook so is there any chance you can PM me the info and the images he sent you - as im very interested in heading in this direction
Yeah the link is just to someone’s page. Not the Facebook post.Originally posted by amorin56 View Post
Just sent a few pictures which he shared with me.Originally posted by blufly View PostAmorin56 - Dude this is music to my ears
Yip primo bro / thanks for sending those thru - it looks like the bag voids are as large as the old models so looks very promising to simply switch out the Stock bags - I would expect this would be very similar with the front bag location also - this then gains back the missing stock ballast that the gen3 G needs -
does anyone know if the timer can be managed on the link to extend pump duration or just simple double tap like a piggy back setup
Can you post the pics? Knowledge for everyone is power!Originally posted by blufly View PostYip primo bro / thanks for sending those thru - it looks like the bag voids are as large as the old models so looks very promising to simply switch out the Stock bags - I would expect this would be very similar with the front bag location also - this then gains back the missing stock ballast that the gen3 G needs -
Havnt uploaded pics b4 do hope that worked
looks like there is slot of space forward of the bag access panel but also more room aft
Looks really promising - so really a simple fix for nautique - same bag as previous.......
Yup that worked. Hard really to tell from the pics. The cavity isn’t identical to the old G. Looks shorter in height to me. Also that pic of the room is ahead of the current bag fully stretch out? Hard to believe there is that much room ahead of the bag.Originally posted by blufly View PostHavnt uploaded pics b4 do hope that worked
Potential bag draining issue from the front section due the the structural hull rib below the hatch but some creative plumbing can prob get around that
looks like an ideal location to also put lead that is out of the way for the ones that don’t need to trailer there boats
Probably a dumb question but how would you keep the lead in place, looks like lead bags would just slide around? Newbie hereOriginally posted by blufly View PostPotential bag draining issue from the front section due the the structural hull rib below the hatch but some creative plumbing can prob get around that
