Originally posted by Skidave
View Post
i just picked up my boat from winterization with oil change. the invoice said Rotella 15-40. I questioned them, and stated I thought there was a change from PCM. They said they were not aware of the bulletin.
Should I take the bulletin to them and have them change it or let it slide until next oil change?
Also, is there a PDF version of the bulletin I can print out?
Thanks
It probably won't hurt it, and if it does, they're a dealer, so they should be responsible.
They should certainly be aware of the bulletin. Kinda scary that they aren't.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Yeah, considering 15w40 was go to for...like...ever. You be fine. Not that I have any evidence it matters, but what i try to do is when i use my boat when cold out I let engine warm up extra long to be sure oil is warm and flowing without raising the oil pressure.
P.S. PDF would be nice...
thanks guys, i think i will let it be and have them change it at the beginning of summer. I will point out the bulletin again.
the image posted on this thread is super blurry when printed. can someone post a clear version or the pdf?
thank you
This oil fits the bill. 5w-30 and Dexos certified.
https://rotella.shell.com/en_us/prod...ngine-oil.html2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
I just put it in my H6 engine this weekendOriginally posted by Evening Shade View PostThis oil fits the bill. 5w-30 and Dexos certified.
Possibly who knows for sure. I would find it hard to believe that using this oil is going to have a detrimental effect on the engine. Everything in the specs and documentation show nothing but better than the standard with no cautions of using it in any application that the non synthetic versions.
Hope so, just put about 4 hours on my boat with this oilOriginally posted by bturner View PostPossibly who knows for sure. I would find it hard to believe that using this oil is going to have a detrimental effect on the engine. Everything in the specs and documentation show nothing but better than the standard with no cautions of using it in any application that the non synthetic versions.
Picked up 2x jugs of Royal Purple this week.... now Gen2 Dexos certified2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
I jumped from the 15W-40 Rotella in the engine originally (on my third oil change) to Rotella 5W-40 T6 full synthetic. I called PCM to discuss as I did this; while they thought this was overkill to use full syn, they said it was fine to use. I will stay with this oil. I change way in advance of the hours requirement, but not in advance of “120 days” as this bulletin advises. I’ll sleep fine with my plan.
