How hard is that to do? could my powdercoat company do that?
I would stay with the lighter colors. The problem with PC is that it tends to fade because there isn't much UV protectant in the paint and no clear coat.
Also, when you PC the windshield, it's a BEOTCH to get it back together because of the thickness of the PC on the inside edges. It's a pretty snug fit on the back edges of the frame. If you could somehow prevent PCing the inside edge with temp masking tape and not see the edge, that would be best for reassembly. Use plenty of soapy water to get the rubber gasket back together and DO NOT BREAK the glass. CC will bend you over and not provide any vaseline.
Chris
