Re-painting FCT help me choose
  • Alan-S
    • Nov 2004
    • 161
    • Richmond, VA
    How hard is that to do? could my powdercoat company do that?
    • SNMike
      • 1001
      White windshield look's cheap to me. Just my humble opinion. :grin: Good luck!! Mike
      2007 Ski Nautique 196 Limited/ PP/ Mods
      • wakejunky
        • 679
        • Ca
        • 2003 SAN
        I would stay with the lighter colors. The problem with PC is that it tends to fade because there isn't much UV protectant in the paint and no clear coat.
        Also, when you PC the windshield, it's a BEOTCH to get it back together because of the thickness of the PC on the inside edges. It's a pretty snug fit on the back edges of the frame. If you could somehow prevent PCing the inside edge with temp masking tape and not see the edge, that would be best for reassembly. Use plenty of soapy water to get the rubber gasket back together and DO NOT BREAK the glass. CC will bend you over and not provide any vaseline.
        Chris
        • Alan-S
          • Nov 2004
          • 161
          • Richmond, VA
          Haha, thanks a lot guys. It looks like I am going to make the bottom legs match the upper part of the tower. Its the most affordable and easiest to do. Still need to decide if I am going to paint the windshield.
            • 2909
            • Current 2017 GS22
            A clean single bead of electrical tape may solve your windshield woes. Covers up the scratches and offers protection from getting more.
            • Alan-S
              • Nov 2004
              • 161
              • Richmond, VA
              #21
              Brilliant! That will def. make me feel better until long term solution is found. Thank you.
              • Hollywood
                • Sep 2003
                • 1930
                • WIIL
                #22
                black or navy tower, keep it simple. The white/white and gray/gray don't look like they belong.
                • mgaspence
                  • 81
                  #23
                  I like the blue accent with striping for both the tower and windshield. You have alot of white on the boat. The blue looks badass. Ties it altogether.
                  I have a SAN 210 white hull, black/red stripe, black FCT
