G-series in floor cooler
  • Neverenough
    • Sep 2012
    • 907
    • Ft. Worth Texas
    • G
    Got a little advice from the Swankster and did this deal.... I had the floor out anyway so what the heck!! Ended up using 4 cans and put floor back in while its was somewhat soft. My luck is it will probably squeak like crazy!!!
    • Cpan13
      • Jan 2016
      • 350
      • Canada
      Man I wish my G21 had an in floor cooler.
      • G_WaTT
        • Apr 2017
        • 104
        • CA
        • 2018 SAN G23
        DIY projects on boats over 100k... scary. Anyone try this and unhappy or have regrets? I am embarking on a G23 quest, and while I may not have the courage now; I think I can get there
        • SJP
          • Mar 2016
          • 16
          • Lake Havasu City, AZ
          • 2014 G23
          They should do this from the factory.
          • Schwiiing
            • Mar 2008
            • 129
            • Norris Lake, Tn.
            • 2017 SAN G23 H6
            Agreed, cooler insulation should be OEM
            • jshack01
              • May 2012
              • 139
              • Louisville, Ky
              • 2020 Super Air Nautique G23 (Gold/Onyx Black) 2017 Super Air Nautique G23 (Indigo Blue/Onyx Black) 2012 230 SANTE (Red/White)
              #21
              I'm thinking it is now? At least that's what I understood it to be on the 2017's. It comes with a cooler but I think it is insulated in the floor now too.
              • Neverenough
                • Sep 2012
                • 907
                • Ft. Worth Texas
                • G
                #22
                30 bucks and a couple hours work well worth it. I like making things better even if it was 100k plus boat. I know this much I dont have a cooler in the middle of the floor and itsworking pretty good!! Had ice in still today about 24 hours later.... its not a 100 degrees out yet but I would assume it works as good as any igloo type cooler. I still haven't decided on weather striping but all in all pretty dang happy I did it. Thanks Swankster for talkin me into it!
                • VinnyQH
                  • Oct 2016
                  • 18
                  • Portland, OR
                  • Fuchsia 2015 G23
                  #23
                  Does anyone know if the 2015 G23 needs to have this done?
                  • Neverenough
                    • Sep 2012
                    • 907
                    • Ft. Worth Texas
                    • G
                    #24
                    Mines a 15 and was not done. So far it was worth the time.
                    • charlesml3
                      • Jan 2008
                      • 2482
                      • Lake Gaston, NC
                      • 2022 G23
                      #25
                      We did the same thing on my brother's 2007 SV-211. The cooler is over on the side under the cushion behind the driver. There was no insulation around it at all and the engine heat would melt all the ice out in no time. We filled in all around and under it with foam insulation. It made a HUGE difference.
                      -Charles
                      • Schwiiing
                        • Mar 2008
                        • 129
                        • Norris Lake, Tn.
                        • 2017 SAN G23 H6
                        #26
                        FYI..... the 2017's do not come insulated.......... on my list for next winter.
                        • jshack01
                          • May 2012
                          • 139
                          • Louisville, Ky
                          #27
                          @Schwiing - That's good to know. Maybe I should email Nautique and tell them to correct their 2017 G23 Product Walk Through video. https://www.youtube.com/watch?v=j_YRWVnayf0 cut to 10:30.. But easy enough to take care of yourself.
                          • cbeitel123
                            • Mar 2017
                            • 60
                            • Los Altos, CA
                            • 2017 GS20
                            #28
                            Does a Yeti fit in there?
                            • Beg4wake
                              • Oct 2014
                              • 563
                              • Radford VA
                              #29
                              nope...unless its a Roadie maybe, but then that's a waste of space. But even those may be too tall
                              • GS77494
                                • Mar 2017
                                • 8
                                • Charlotte, NC
                                #30
                                Has anyone used the AO soft-pack 38 cooler? Saw a few reviews on Amazon from Malibu owners saying that the height and other dimensions were perfect for their boats.
                                https://www.aocoolers.com/coolers/ca...ler-black.html
                                I have a G21 being built, so bought one in hopes that it'll be a good fit for under one of the seats.
