All I got to say is right on!
So someone do the math here :-) .... 63 gal tank..... Let say 2 times more efficient (altho it will likely be 3 times with all the ballast we run...) how often you guys need to fill up? K... Cut that in half. Just sayin! Most guys havta pull out a couple times a season for warranty work/maintenence type stuff (am i right?) and you can legally run off road diesel! Cha ching!
If you look at the tail pipe on a new urea equipped truck like mine, the inside of the tail pipe is not even black.
And how much is the 550hp motor again? Yes the diesel option would be more inevitably!
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
. Basically what we are saying here is the torque curve of an Eco boost or a diesel engine better matches the needs of a wake/wake surf boat than a high revving higher horse power V8. Regardless a diesel will be more efficient.
