WHAT IF G23 with a duramax diesel?
  • Bimmerboyz
    • Feb 2009
    • 378
    • Herriman UT
    • 1978 Ski Nautique that I miss:-( 2003 SANTE
    #46
    I like the idea of a diesel, it weighs more so less ballast, the RPM range is broad enough for our boats that barely go above 45mph. It makes sense with how stupid big the G23/25 are.
    However I would prefer the next development to be an electric motor. Use a Diesel motor to power a generator that powers an electric motor. Crazy amount of torque and quite efficient.
    • 79nautiquenick
      • Jun 2010
      • 76
      • charelston, Tn
      • 07 236/230 79 Ski Nautique 2,000+hrs clocked
      #47
      Originally posted by hotrod508 View Post
      Actually i know exactly what the gas usage is... When talking with others who have G23s there are various reports. Nobody is getting better than 4 or 4.5 unless its parked. Just observation. We ride at lunch one run apiece.... 20 per day. I own a 236 with the zr6...It uses about 2.5 to 3gph even loaded.
      Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
      i have a 236 as well with the zr6 and loaded for wakeboard i get around the same as you. surf is a little different, we get roughly 4-5gph.
      a turbo diesel g23 would make sense for less gas consumption, the only down fall is......how much heavier will the g get once that heavy cast iron block is thrown in the rear, i believe a 3-4 axle trailer will be required just to haul the 23 little a loan the 25.
      I love the g23 and would love to have one, but once the numbers fuel consumption numbers started showing up on the boards, my 236 became a lot nicer!!
      Currently own
      07 230/236 TE (all white )
      79 Ski Nautique
      • prairiethunder
        • May 2009
        • 84
        #48
        what about twisting a v-drive to bits...or the tranny with all the torque? just my 2 cents.... avoiding turbo lag on hole shot is probably a challenge
        HIT IT!
        wait for it
        wait for it
        oh crap, my board isn't in the right spot anymore I'm not ready
        oh, we're going......
        It\'s Good to be Here
        \'97 SN
        • Zach@n3
          • Sep 2012
          • 736
          • Indianapolis Indiana
          #49
          Variable vane turbos eliminate turbo lag. Take a look at all of the technologies that have entered via diesel engines in the past 10 years.
