Stopping water intrusion while surfing a 2005 SAN
  • msbowhunter
    • Aug 2011
    • 100
    • collierville tn
    • 2011 SAN 210
    How bout a wide roll of blue painters tape? Removes with no adhesive left behind
    • TxJole
      • Jun 2009
      • 898
      • Cedar Creek Lake TEXAS
      U can get all kinds of crash wrap, wrap-a-wreck and other brands online for 36"x100' for $40 and cut it on the roll with a band saw to length.
      • johnboyy7
        • Oct 2009
        • 409
        • houston
        Originally posted by lztat573 View Post
        On my 2007 211 I cut out a piece of plexiglass the shape of the vent and then cut a smaller hole in the front of it, and it is usually above where the water comes in at now. some times it gets to that point but doesn't fill the boat up as fast. I took the vent cover off and put it under the cover and you can't even see that it is there. I have my cover over it for winter, but if you would like a pic i could get one for you and let you see.
        i would very much like to see a pic of this. please sir.
        04 SANTE 210
        89 SPORT
        • markj
          • Apr 2005
          • 1194
          • NorCal
          Oh man... You said "crash wrap" not "cash wrap". I need to learn how to read mo betta. I Googled it and that looks like it will work well. Thanks. No wonder they looked at me funny when I asked for cash wrap.
          • lztat573
            • Aug 2006
            • 89
            • Idaho
            • 07 SV211
            Here is my vent with the Plexiglass behind. If you need or would like any other pics let me know
            • fech98
              • Mar 2012
              • 57
              • Arizona
              • 2004 sv211TE
              #21
              IS that plexiglass permanent? Do you leave it on all the time? We only surf portside, so would that be enough air just by using the other side?
              • markj
                • Apr 2005
                • 1194
                • NorCal
                #22
                The blue painter's tape worked perfectly. It was so easy. I can't believe I didn't think of that. Thanks!
                • fech98
                  • Mar 2012
                  • 57
                  • Arizona
                  • 2004 sv211TE
                  #23
                  Can you show a picture of how you put the tape on? The correct location to work for you?
                  • markj
                    • Apr 2005
                    • 1194
                    • NorCal
                    #24
                    You just run it parallel to the rub rail with a few inches extra on either side for grip to the hull so it doesn't fall off. Simple.
