750 install
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    RE: 750 install
    cool thanks, what about the pannels
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      RE: 750 install
      I did not reinforce mine yet, but I need to as they bow inward when the bags are full. That is a winter project this year. I am thinking about using some more modern materials like what they are using now. The black panels on the new boats look good with no carpet on them, but I am just curious as to how it affects the engine noise. I would think that the carpet helps knock some noise down. Once I get started on it I will post a thread.
      2001 Super Air Nautique
      Python Powered
      100 Amp Alternator
      Dual Batteries
      Many upgrades coming...
      • Chattwake
        • Apr 2008
        • 341
        • Chattanooga
        • 2010 SANTE 230 - Sold 2009 SANTE 230 - Sold 2008 SANTE 230 - Sold
        RE: 750 install
        I plan on jerking the hard tanks out of my 230 this winter and replacing them with 750's too. I'll take some pics.
        2012 Axis A22 - on order
        2011 Axis A22 - sold
        2010 SANTE 230 - sold
        2009 SANTE 230 - sold
        2008 SANTE 230 - sold
        2007 VLX - sold
        2002 XStar - sold
        1990 Prostar 190 - sold
        www.chattwake.com
        • jward
          • Feb 2008
          • 620
          • 03 SANTE 04 SANTE
          RE: 750 install
          Great day! Went out with wakeboard1 and we tried out my 750 sac install. Worked great.. Both of us got in a good set under some great weather. Couldn't ask for a better day.
          Alright, for those of you always looking to save a buck like me, here is how I did this by using the aerator pumps instead of buying high dollar ballast puppies:
          Gut the hard tanks, but leave your hoses in place.
          From the fill hose connect a "T" fitting so that the water has to go right or left when it comes out of the hose.
          Connect a short hose to one side of the T- connect that hose to the bottom fitting of your sac. This will now fill the sac.
          Connect a short hose to the other side of the T -connect this hose to your empty pump - connect your factory hose to the empty pump so now the water can pump out the side of the boat.
          All thats left is to connect your overflow hose to the top of the sac. You need to put a shut-off valve in that hose.
          What I did with the empty pump.
          When you take out your tanks you will see a small area where the empty pumps are when attached to the hard tanks. Kinda like a box with no top on it. I Mounted my pumps in there. I didn't want the sacs to put any pressure on them so I cut a piece of treated 2X12 to cover the pumps. Painted them black for now, may get matching carpet later. Leave 6" or so for all of the hoses to come up from the pump.
          For this to work, you kinda have to run it like the piggy back method. Open your valves on the overflow, and plug the empty holes on the side of the boat. fill the sacs, close your valves on the overflow. Smile while you stand in ankle deap water on your swim step. Ride till you can't anymore. Then take out your plugs, drain water and go get a massage from the lady friend.
          Pretty easy. If anyone needs pics let me know.
          • intrlaz
            • Aug 2009
            • 230
            Re: RE: 750 install
            I did something similar, but just took the carpeted pieces that covered the stock tanks and cut 6 inches off the long side.
            • jward
              • Feb 2008
              • 620
              • 03 SANTE 04 SANTE
              #21
              RE: Re: RE: 750 install
              I thought about that. Then I thought if I ever sold the boat, I want to be able to set everthing back to stock depending on the desires of the buyer.
              • jward
                • Feb 2008
                • 620
                • 03 SANTE 04 SANTE
                #22
                Had a few request for pics so here you go.
                • jasonwm
                  • Mar 2009
                  • 19
                  #23
                  Nice install, thanks for sharing the pics!
                  For anyone that is looking for some new ballast puppy pumps (or any ballast products for that matter), we do have a discount available for Planet Nautique members, so shoot me an email for more info.
                  WakeMAKERS.com
                  Contact us for exclusive Planet Nautique Member discounts!
                  • MBKY210
                    • Jun 2011
                    • 3
                    • Lexington, KY
                    • '95 Sport Nautique '03 Super Air
                    #24
                    Sorry to revive an ancient thread, but didn't want to start another ballast thread. I have an '03 SAN. I replaced the rear tanks with fly high bags over the weekend. I did a straight swap. Drain pump at the rear bottom fitting of the bag, fill line to one of the top fittings, and vent line to the other top fitting. After reading jward's posts it appears I may be missing something. Am I going to have issues when I try out the new setup tomorrow? The only problem I can think of would be the additional volume of water pushing through the drain pump and out of the boat. If this happens I'll just install an inline valve. Any other problems I need to be aware of?
                    Thanks.
                      • May 2026
                      #25
                      If you stuck with the same pumps (which it appears you did), you are going to have some long fill and drain times, as I believe both of those pumps are off a 3/4" thru-hull. Other than that, I think the 2003 setup should work. I think you are going to have to close the ball valve though to keep them from draining when at rest. I'm not super familiar with the 2003 setup (which is different from the 99 and 2000 setups that I am familiar with), but I think that the 2003 stock system still uses the combination of a closed vent line coupled with a hard tank to prevent water from flowing past the propeller in the aerator pump on the drain line. This does not work with soft bags, because they just compress. The hard tanks can't compress, so they hold the water in because they have no air to replace it with. It's a vaccuum / pressure thing.
                      But I could be wrong about how yours works. There may be a relay with a gate valve on those lines, so you might be okay. You should find out pretty quickly though, and if they are draining when you don't want them to be, just close the ball valve.
                      • MBKY210
                        • Jun 2011
                        • 3
                        • Lexington, KY
                        #26
                        Thanks for the info. I guess I'll find out if it works today. I'll post how or if it works in case anybody is thinking of trying this.
                        • Drock
                          • Oct 2010
                          • 32
                          • BC, Canada
                          • 03 SANTE 210
                          #27
                          Please Do, I have my 750's sitting here in boxes ready to go with the exact same plan(straight swap for hard tanks).
                          D
                          03 SANTE 210
                          • Texan1554
                            • Apr 2011
                            • 220
                            • Dallas
                            • 2002 SANTE
                            #28
                            In the same boat, looking to make a straight swap as soon as my bags get in.
                            2002 SANTE
                            • h2ohangtime
                              • Aug 2009
                              • 92
                              • Frisco, TX
                              • 2002 Super Air Nautique
                              #29
                              ^ Chexi is dead on with this one. I had the exact same problem last year when I tried to attach the stock Rule 1100 GPH aerator to the empty port in the 750. It would just push the water out and we'd have a half-empty bag after a couple minutes. You'll either have to put a manual valve in the empty line or go with the puppies.
                              • MBKY210
                                • Jun 2011
                                • 3
                                • Lexington, KY
                                #30
                                Tried out my setup last night and I would say it was successful. Just to clarify... '03 SAN, I replaced my hard tanks with 400# sacs... straight swap so the fill/drain system is stock... just have bags instead of tanks. Sacs filled easily and quickly (~6-7 minutes). If I lost any water out of them while riding it was minimal. This may be different for 750s. The extra water in the 750 may push through the drain line. This could easily be fixed with a manual valve. The sacs drained easily and quickly also. There may have been a gallon of water or less left in the sac after draining. No biggie in my opinion.
                                Maybe one day when I have the cash and the time I'll go the ballast puppy route, but for the time being this will work...ballin' on a budget for sure.
