What could possibly go wrong with a great idea like this......
I would not do it!
The trailer is likely setup to be properly tongue-weight balanced with an un-ballasted boat. Putting an extra 1500-2000lbs of mass at the back of the trailer is a recipe for negative tongue weight and unstable trailer sway that could get dangerous
Also, with a 2wd vehicle, the negative tongue weight could lead to a loss of traction on the ramp and you might not even be able to get it out of the water.
The only vehicle on your list legally capable of towing the GS24 (7800-8200-lbs) or the G23 (8500-9000-lbs) BEFORE adding ballast is the Suburban you listed. If you have a private ramp at your lake house, the mid-size SUVs you listed are fine to pull the boat from the garage and drop it in the water, assuming the hitches can handle it, but towing on a public road would be irresponsible.2019 SAN G23 | 2016 SAN G23 | 2013 Wakesetter 23 LSV | 2008 Wakesetter 23 LSV | 2003 Wakesetter 23 LSV | 2000 Wakesetter VLX | 1998 Sanger V210 | 1994 Magic Sceptor 28 | 1985 Cole TR2 | Too many PWC to count!
