Swing away tongue conversion ?
  • rossrips7
    • Feb 2010
    • 233
    • Unknown
    Has anyone ever converted a ramlin with a bow stop crash pad to a swing away tongue?
  • 74corvette
    • Aug 2010
    • 45
    • Des Moines
    • 2001 Super Air Nautique
    I have a 2001 SAN with a dual axle trailer, couple years ago I had the tongue converted to a swing away using a weld on Fulton kit. Let me know if you want photos.
    • 74corvette
      • Aug 2010
      • 45
      • Des Moines
      And yes it is a Ramlin trailer.
      • Blamey
        • Sep 2015
        • 595
        • New York
        Does your trailer not swing up?
        • xlair
          • 694
          • Wisconsin
          Ramlin does make a swing kit. A guy on here did it 5+ years ago. Maybe you can search for it. Otherwise call Ramlin?
          2001 Pro Air Nautique
          • rbalan
            • 328
            • Georgia
            • 2002 SANTE
            74corvette could you post a photo or 2? I'd like to add the Fulton Swing to my Ramlin, but there is only 2 inches of 3 x 3" trailer frame for it to slide into. According to Etrailer/Fulton, it needs a full 3" for structural soundness. I may be able to cut/grind where the side rails are welded to it to make it work, but would rather not.
            • 74corvette
              • Aug 2010
              • 45
              • Des Moines
              I will get photos shortly. I got another piece of 3x3 to use as the extension for where the brake actuator bolts on. I would, if you haven't already, convert over to disk brakes while your at it. Did mine this year and wasn't hard at all. Plus I hated messing with drum brakes.
              • 74corvette
                • Aug 2010
                • 45
                • Des Moines
ID:	526627Click image for larger version
                • 74corvette
                  • Aug 2010
                  • 45
                  • Des Moines
ID:	526631Click image for larger version
                  • rbalan
                    • 328
                    • Georgia
                    • 2002 SANTE
                    Thanks for the pics, I was planning on putting the hinge between the bow stop and trailer. I may need to rethink my plans.
                    I may do discs someday, from what I recall don't you have to have an actuator made for discs?
                    • 74corvette
                      • Aug 2010
                      • 45
                      • Des Moines
                      Yes, you need to have an actuator for disk brakes to also include one if your have single axle or dual axle brakes. I have a dual axle trailer but only have brakes on the front axle. I would find it tough to have the swing away between the bow stop and the trailer, it will need to be in between the bow stop and the tongue.
                      • TRBenj
                        • May 2005
                        • 1682
                        • NWCT
                        I am having a '93 cc trailer (essentially the same design used through '02) converted from hinge up to side swing, using the factory Ramlin (03+) swing design as inspiration.
                        Where are you located?
                        1990 Ski Nautique
                        NWCT
                        • rbalan
                          • 328
                          • Georgia
                          • 2002 SANTE
                          I'm in Georgia. Make sure you take before and after pics.
                          • TRBenj
                            • May 2005
                            • 1682
                            • NWCT
                            I can ask about getting a kit made up for you if you're interested, he is already CNC programming the cuts for the top/bottom plates. Would still require cutting/welding, obviously. Shoot me an email: TRBenj@gmail.com
                            1990 Ski Nautique
                            NWCT
                            • Fgroce
                              • Dec 2016
                              • 179
                              • Middle Georgia
                              • 2002 Ski Nautique
                              Rbalan what part of Ga are you from?
