Recommended kits for converting drum to disc brakes
  • 74corvette
    • Aug 2010
    • 45
    • Des Moines
    • 2001 Super Air Nautique
    I have a 2001 SAN on a dual axle Ramlin trailer. I am looking at converting the trailer to disc brakes and was seeing if anyone recommends a certain kit. The trailer only has drum brakes on the front axle but want to add disc brakes to both axles. Thanks for the help
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    https://www.etrailer.com/question-25599.html
    I would call either these guys or ramlin. I dont know of the top of my head if this is going to require a new actuator or not, depending on how much hydraulic fluid/pressure it takes to actuate discs vs drums and going to both axles.
    tim
    • Blamey
      • Sep 2015
      • 595
      • New York
      You will most likely need a new actuator and will need to switch to 5 pole connector that disables the breaks in reverse.
      Why do you want to switch to disk brakes?
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        these guys helped me convert from oil bath single disc to greased bearing double disc on my trailer. the folks in Tennessee actually were engineers on the phone and understood exactly what I needed to do. http://www.ufpnet.com/
        2005 SV-211
        • azeus17
          • Feb 2008
          • 387
          • Grand Rapids, MI
          • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
          Does your tow vehicle have a brake controller? If so, I would go with electric brakes and dump the hydraulic all together.
          https://www.etrailer.com/Trailer-Bra...EBRK-7-SA.html
          Note: These are just an example...I don't know if they will actually fit your setup.
          • 74corvette
            • Aug 2010
            • 45
            • Des Moines
            I ended up going with a UFP disk brake kit through Pacific Trailers. Installation was straight forward and so far so good. I recommend anyone with drum brakes to convert over to disk, so much easier to maintain.
