Yes, mine are wired into the Overhead Light circuit in the tower, which is probably what your speaker LED rings are using as well. If I want to run just the speaker LED rings without the light bars on, I just unplug them at the light bars.
I was underwhelmed with my light bar. I put one on hoping that I might be able to slowly cruise the lake at Powell and the amount of reflected light from the front of the boat and lack of projection made the light unusable with this use. We couldn't see very far and the reflection was just too great.
OK, with the forward-facing lights, what problem are you trying to solve here?
Docking lights are there so you can easily see the dock when you're 25 feet or less away from it. They all do a pretty good job of that.
-Charles
Exactly. Docking lights are not headlights for boats. It doesn't work that way no matter how many bulbs and bars you install.Originally posted by Blamey View Post
In addition, due to the increased popularity of dock lights , they have become a major problem with inexperienced boaters using them across all waterways thinking they are navigation lights while driving . Any passing boater gets blinded when someone is using docking lights.Originally posted by charlesml3 View Post
