I just acquired a perfectly good OEM factory head unit and separate Amp from a 2006 SANTE with CDM4 head unit. I want to install this in my 1996 Super Sport. Anyone with experience on this? Will the large face fit into the space already there on the Dash or will I have to do some modifications? Seems like a simple install with manuals available on-line and in-print.
It should fit the opening in the dash as the chassis appears to be standard DIN size. The face of the CMD4 is much bigger than single DIN so I don't think the factory splash cover will work but it should fit the opening.Shawn
2012 Blue Metal Flake SAN 230
Thanks! I've got to figure out how to wire this whole thing up when I get the boat back from the detailer. I haven't messed with 12V audio since the 80's. Eeeek
Ok, I smartly elected to have Premium Sound, a nearby audio installer put the head unit, new face plate needed, and the amp into the boat the other day. Now I have a professionally installed foundation for future mods. I'm very pleased with their work, and now it is clear I need new house speakers for the boat. I'm likely to buy Polk MM651UM speakers, since they are rated very high, and are not out of reach, budget-wise. I'm also adding the Bluetooth module that Swatguy recommended so highly.
I can see one thing clearly....while I might be reasonably capable of complex projects, I prefer the skills of professionals on some things where inexperience or willingness to accept the shortcomings of my own experience are not a sacrifice I want to make on this boat. On my first boat, a semi-project Supra Mariah, this was rarely the case, since I had so little invested in the basic boat. Things change. I suppose when I upgrade next time, it will be to an even more complex boat, e.g. SANTE or 211V.
