1990 SN Stereo Wiring Help
  • dtbrown
    • Sep 2005
    • 14
    • Bartlett, IL
    My 1990 SN had a non-working cheap stereo in it when I got it. Once I pulled all of the components out I realized that there was only a positive-red and negative-black wire running to the stereo head unit. My question is, where do I tap into a "switched" wire? Where would this wire be located(component it is hooked up to) and what color should it be? There is an illumination wire in the harness, is there a corresponding wire for that as well?
  • M3Fan
    • 1034
    RE: 1990 SN Stereo Wiring Help
    The switched wire would go right to the ACCESSORY 1 or 2 breaker. The constant 12V power should go right to the battery with a decent gauge wire (with inline fuse), as should the ground. Just my recommendation. You don't want to put too much draw through the dash. I don't know about the illumination wire on the stereo- I'd just connect it to the switched power I suppose.
    2000 Ski Nautique GT-40
    2016 SN 200 H5
    www.Fifteenoff.com
    • dave210
      • Jan 2006
      • 113
      • jax fl
      the accessory switch wire is orange or orange with a blak stripe
      • M3Fan
        • 1034
        I should add that you can probably put the ground to the LED indicator next to the ACCESSORY switch which terminates at the ground for the dash.
        2016 SN 200 H5
        www.Fifteenoff.com
