I need some help putting a small setup together ('96 supersport). The more I read the more confused I get. All topics are for systems 10x the power of what I'm shooting for.
I don't need a big system at all - no tower speakers for now. I just want to have something you can hear while under way.
Right now I've got 4 Polk db651's running off the deck (whoohoo). I want to put the sub under the kick panel in a sealed box roughly 1 cubic foot. That's all there is room for.
Might stick a small 6" speaker in the vicinity of the sub just for the driver
The alpine 10" type R is what I had in mind.
I intended on the kicker ZXM700.5 for power.
-With the sub rated for 300w and the amp slightly less at 210w, will this work? (Both rated 4 ohm)
-if I power the in boat speakers with the other 4 channels will there be an improvement in volume and/or quality? Is there any point to this one?
-if I'm off track is there a better or cheaper way to go?
Like I said, just want to hear things when moving and have some better quality when chilling.
Thanks for any help
Thanks for any help
