I had a new system installed and he can't seem to get rid of background noise. When engine is off, there is no noise which is part of the problem as he's working on the boat in his garage so when we check it out it sounds great. Once we're on the lake, there's background noise when the boat is running and worsens when accessory button like the ballast pump is turned on. Any suggestion?
If Ground is already at battery... Do as MLA states and check B+. Try and also have it at the battery. When you get background noise in your stereo is because there is interference in your power sources. If all else fails look for a noise eliminator and run it in your power cables to your stereo.
