Hooking up SYN4 and pair rev8 to stock switch
  • core-rider
    • Feb 2004
    • 1369
    • Huntsville, AL
    • 2003 Black SANTE
    That is a better route to go in the long run IMHO. The 1/0 awg cable will be enough to run most systems unless you just go crazy power. The 1/0 awg isn't cheap, but I think it's easier and cleaner looking than running mutiple wires for multiple amps. Just search online an you will find many places selling the cable, fuse holders, etc. The cable won't need to be "marine rated" unless you frequent salt water. Being in SLC I don't think you will. Good quality copper cable should be fine. I would suggest a fused distribution block. It's always a good practice to fuse all leads. Your 1/0 awg cable should be fused for the total load, and the distribution leads fused for their respective loads.
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      Originally posted by ericchile View Post
      OK I am starting to rethink this and better future proof this. (Although I don't anticipate changing it myself).
      I think I will rip out the 8 gauge wire going to the stock polk 500.4 amp that powers the in-boats and stock sub.
      Then I will run a 1/0 gauge marine wire (still figuring out where to buy) with 150amp fuse right off the perko switch. At the end of the 1/0 wire I will put a 4 block connection (does this need to be fused to protect the small run of 8 wire since the amps are already fused?) and then reuse the 8 gauge stock wire here. It looks like the run from the perko switch is about 20-22 feet. I don't know why they didn't put the battery isolater on the port side of the boat so the run to the HU area would be shorter and not have to cross the engine!!
      Thoughts?
      I am still trying to figure where to find the connector to the wires that come out of the tower to the amp board. Picture in previous thread.
      Thanks for working through this with me. I am learning a lot (real reason for not paying a shop).
      Eric, this is by far the cleanest route to take when adding more amps to a boat that already has a couple. Come right off the "C" post of your switch to the breaker, then on to the amp area. Take your amp's GND from the closest battery, which will be the port side. You do not need to use marine grade 1/0 cable, just regular amp cable. Since the amps all have their own internal fusing, redundant fusing at the amps is not needed. The main breaker off the switch is what will protect the trunk line from a short.
      Cut out that tower speaker harness connector and dont look back.
      • ericchile
        • 283
        • Utah!
        • 2009 SANTE 230
        So stocked to get these speakers working. Looks like Nautique used 2 gauge from the battery though :-(
        • ericchile
          • 283
          • Utah!
          • 2009 SANTE 230
          Learning a lot about my stereo system. It looks like Nautique ran 6 awg all the way from the starboard side locker counter clock wise all around the boat, up to the bow and down to the port side stereo compartment. I am guessing it is about 35 feet of awg. Then it does a 6 foot loop in the compartment that doesn't need to be there. Then it connects to a bolt on the amp board, which on the other side goes down to a 14 awg wire into the polk 500.4 amp. LOL.
          According to www.bcae1.com there is a lot of voltage drop in that. Why is it like that?
          • core-rider
            • Feb 2004
            • 1369
            • Huntsville, AL
            • 2003 Black SANTE
            Because all boat builders are just that... boat builders, not stereo gurus. CC has been that way for as long as I can think of. Sounds like you have some work ahead of you!
            Jason
            • ericchile
              • 283
              • Utah!
              • 2009 SANTE 230
              #21
              Ha I hear you.
              So I got everything hooked up tonight. First pass and everything is working good. I had to undo just about every black plastic cover and eletrical tape holding wires together. The good thing is that I feel I know my system a lot better. I also know what I need next. I still need to clean up some wires and I am not entirely happy about the location of the distribution block. Is it possible to glue that on the carpet next to the AMP board?
              I wasn't able to turn up the rev8s all the way because it was 9pm and I like my neighbors. I don't have the WS420EQ installed yet but that should be easier once I figure out where I want to put it.
              So far I can say I am LOVING the wetsounds stuff. Crystal clear sound!
              I think I might have just gotten bitten by the upgrade bug. Next a syn6 plus new interior speakers? Or another pair of rev8s? Once I tune this and build a better AMP board I think I will grab something else!
