Hello from the UK,
I've ben adding wetsounds components bit by bit to by 210, initially added SYN4 to power factory speakers and continued to use factory clarions for in boat and sub. Since added WS Sub and WS420. The factory tower speakers weren't great so last year added 4 x Rev10's but still running from one bridged SYN4 - I know it can take more but other commitments so bit at a time.
Anyhow, pulled the boat out this season and noticed one pair of Rev10's not sounding right basically just getting very (very) high frequencies. No warnings on amp. After a bit of switching things around ruled out the speakers and wiring, and inputs. The crossover is set to HIGH, I didn't install but the manual seems to suggests this, I've found that if I select FULL all the speakers are working.
I'm talking the dealer/installer about a replacement but could the issue be caused by the current set-up and/or will running on FULL cause any more problems. I have a WS420 in there so can adjust the sounds to an extent.
Thinking ahead I see the ideal setup would be to run 2 x SYN4 or possibly SD4, will this improve the sound or simply make it louder. I'm on a small lake and can't really go much louder without complaints! In any case and can hear when riding, but getting a clearer / cleaner sound would be of interest.
Any thoughts appreciated.
