Lee- looks awesome.... Really like the amp mount acrylic approach.
what type of sub is that? How many watts?2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
I like the amp mount too. Gear can get stored and amps are still protected! Looks real clean.2013 G23 450 with NSS (175hrs) and still have the original prop
2010 SANTE 230 343 (280hrs)
Thanks for the kind words. The sub is a 15 inch D.A.D and it hits very hard. I've been super impressed compared to a XXX. The amp is a 1500 watt arc audio. The amps are mounted to a custom made piece of machinesd aluminum with plexi cover. People flip out when they see in person
Well that's definitely an A+ install like all of your others....2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
How does the aluminum attach to the hull. Assume brackets at top and bottom?2013 G23 450 with NSS (175hrs) and still have the original prop
the amp rack is screwed into side of boat. all the screws being the amps, so it looks loike the rack is made into the boat. also look at the detail of how the wires are ran behind the rack, super clean set up. the rack alone weights about 50 lbs.
Lee- how are you blacking out the vents and rubrail? What method?2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
