Thanks guys! I'm trying to get this done today! After I'm done I will post up pics! (I think it's going to be a long day!) And I shall use really short screws, maybe only ones that are 1/4 in long!
'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
-GO DAWGS!-
BAD IDEA!!! - use some form of backing either glassed in under the carpet or epoxy - short screws will just come out after the first wake bump - think about it, you just spent over 50k and you are willing to put holes in the hull?2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
A question,
If you want to run 4 tower speakers (4ohm each) from a 4 channel amp (Clarion 480 for example), do you need to change out the speaker wires in the tower? I believe it's a 2 conductor wire.
Or is it possible to connect the speakers in serie and bridge the amplifier into 2 channels?!230 with ZR6 running on propane
ok, so the day didn't quite go as planned. Here's what I ended up doing. Wired the sub to the 2 channel amp bridged to one. Wired the tower speakers to the four channel amp(for some reason only one works and for the life of my I can't figure out why! All I did was disconnect them from the 2 channel amp and connect them to the four.) The four speakers in the cabin were somehow wire to only two channels with only a total of four wire????? two pos. and two neg. The bow speakers are run off the head unit. The JL 6 channel amp is wired from the port side battery with the ground and power(big fuse in the power wire). I decided to leave the power and ground alone with the two factory amps so I will be returning the two distribution blocks. The rca's are connected. I couldn't figure out how the bow speakers came off the head unit. So there is an appointment in the morning at Best Buy. The are going to find out what is wrong with the tower speaker thats not workiong and wire the 6 interior speakers to the 6 channel amp correctly. $120 later I should be good to go and have a big smile on my face! (it wasn't there today for sure!) I will update tomorrow with how things went!'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
-GO DAWGS!-
Sorry to hear all the trouble, your two tower speaker wires should be the purple and green wires (each with a positive & negative). If your tower is wired for four you will need to find out which ones are hooked up to your speakers. If you crawl into the boat and look behind the receiver, you should be able to find the bow speaker wires that are connected.
Be cautious with Best Buy installers, I know it can be hit & miss with their training. They tend to hire young kids with tons of computer training and hardly any real experience. I have heard of some horror stories coming from my local Best Buy. One tech there drilled a hole through one of my friends' Nautique while trying to install an amp to the side. He battled Best Buy for months before they would fix it. Another tech crossed wires in my friends Mercedes' computer and fried it.
I understand that techs are a lot like surgeons, you get what you pay for. So be careful in who you let tune your toys. Find the old school guys with 20+ years under their belt.........that's who I learned from
it's already set up. I talked with the guy yesterday for about an hour with him looking at my boat. He knows what he's doing. I told him not to mount the amp what so ever. That I would take care of that! I don't want any holes either! As for everything else he has to do. Pretty straight forward for someone that knows even a little bit about it. I'm just not the car stereo guy, not mechanical on the engine......I've got that covered!'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
-GO DAWGS!-
Kevfran,
If the best buy guy gets it right celebrate. I would put money he doesn't get it right. The boat stuff is different enough that most car guys make at least one mistake.
You can run the tower speakers off a bridged four channel amp if you rewire them in series versus parallel, this will drop the 2 ohm load to 8 ohms, design load for a bridged four channel amp. The best buy guy will certainly get this wrong and incorrectly tell you that you need to pull two more wires into the tower.
You may need to pull new wires to the boat speakers, some boats daisy chained the wires, paralleling the speakers. The best buy guy should get this right, selling you a bunch of new speaker wire in the process. I would guess this will be done if/when you read this post.
The series/parallel thing as well as amplifier brigding are topics well explained here:
www.bcae1.com
See chapters 38, 51,52.
Best of luck.
Just noticed AuMDLST posted the same thing a few posts back... I thought you already had four tower speakers. Two should run right off the 480 bridged.
Check out the BCAE site if you are interested. Try to focus on the three chapters, you can easily get lost/distracted on others resulting in information overload...
www.bcae1.com
Best of luck.
I'm picking up the boat tonight after I get off work. I will update with how they (Best Buy) did!
Mikeski, when I get some time I will read that article! Thanks!'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
-GO DAWGS!-
Picked up the boat Sat. night and everything is GOOD to go! I forgot to take some pics, but it looks good and sounds even better! About the only thing I was dissappointed with was the fact that our head unit will not turn the volume up any louded! It screams, but could use some more!'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
-GO DAWGS!-
Anyone have any ideas how to turn up the volume louder? I know the speakers are capable of it!'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
-GO DAWGS!-
