Pressure Washer - Battery? Water from Lake?
  • SkiTundra
    • Jul 2008
    • 514
    • Unknown
    Looking for a pressure washer. I'll be pulling water from the lake so need a decent filter of some sort. I also wouldn't mind a cordless electric though I'm guessing for any kind of decent performance it will need to be gas. Any recommendations?
    Thanks,
  • SkiTower
    • 2172
    • Clayton, NC
    can you do that? I would think the washer utilizes the positive pressure from the spigot instead of making it suck the water out of the lake.
    I also don't power wash my boat, except the carpet. hand wash only, clockwise circles... ;D
    2007 SV211 SE
    Tow Vehicle 2019 Tundra
    Dealer: www.Whitelake.com
      I have used a ballast bag pump, to supply lake water to my gas pressure washer. Works good.
      • WaterWeenie
        • Nov 2012
        • 17
        • Alexandria, MN.
        Karcher electric pressure washers will pull water from the lake. I have two of them. They work great...
        http://www.karcherresidential.com/us...t/16033000.htm
        • ES
          • Sep 2011
          • 234
          • Northern NC
          Same here: I use a separate water pump I tie to the boat lift and drop under the boathouse. Make sure you don't get a very cheap one, otherwise you may not get enough throughput to feed the pressure washer properly.
          • SkiTundra
            • Jul 2008
            • 514
            • Unknown
            Thanks for the input. I just ordered a Karcher. We'll see how it does.
            • Paxdad
              • Mar 2013
              • 775
              • Cumming, GA
              • 2008 210 SANTE
              I have a karcher as well and it does not need a filter unless you are really adamant about it having one. I used to connect to my RV gray water tank discharge and suck from there to wash motocross bikes etc and never had a problem with debris etc. The only issue I had with the Karcher was that the GFCI plug was a POS. I finally cut it off and ran a straight male 3 prong plug as everywhere I use the pressure washer is GFCI protected already.
              2008 210 SANTE
