Do you think that there would be any interest in a 6 light light bar for 300$ versus the ones I have seen on Buywake for 700$ and Up?? also I have made a filler cushion for the walk through, I was thinking about selling both things on e-bay or offering them up here for Nautique owners. I will post pictures in the next day or so. Let me know your thoughts. If anyone is interested, let me know.
Sorry this took so long
Check out the Pics. I am in NO Way a professional. but the cushon turned out super nice I think. The corners could have been pulled tighter I think, but I am happy with it. I used Black because I thought it looked Nice. I could do this in the off white color of Most Nautique interiors. I also used 1" treated Plywood and Anti-Bacterial foam in the cushion. It fits snug, doesn't bounce around, but can easily be kicked out of the way in a hurry. As a side note, I makes a nice dam when you aren't paying attention and 7-10 gallons of water come over the bow!
Light Bar
the light bar turned out Way better than I thought it would. Although, after realizing that You can't Ride/tube/ski after sunset on Most lakes (by Law in some areas) It IS Overkill! but It still lights up the Boat and area pretty well. Specs: 6 50watt Halogen lights fully encased in plastic/glass housings. Aluminum bar, and Aluminum clamps. the clamps are dipped in a rubber coating to keep from marring the tower. the light is switched using an unused factory switch on the dash pad. (I used the heater switch because I don't have a heater) let me know what you think. not bad for an afternoon or two of work.
