Best anchor?
  • Smbailey
    • Mar 2019
    • 15
    • Smith Mountain Lake, VA
    • 2003 Nautique Super Sport 210
    Best anchor?
    Shopping for an anchor for our 2003 Super Sport 210. We are in a lake with lots of underwater timber and possibilities for entanglement, and want something that will hold tight through rougher wake. Suggestions? Thanks!
  • GMLIII
    • May 2013
    • 2821
    Post edited to remove unnecessary quote. See Quote Guidelines <-- here.
    I have been boating on SML for 50 years and have used the Greenfield anchor with no problems with any underwater entanglements
    https://greenfieldproducts.com/anchors/river-anchors
    Click image for larger version  Name:	riverteal.jpg Views:	285 Size:	40.7 KB ID:	580470
    • srock
      • Oct 2008
      • 1158
      That anchor would never work for me on my sand bottoms or ocean floor. I'm curious, does it work because it grabs the timber without getting stuck?
      • GMLIII
        • May 2013
        • 2821
        Yes you are correct. The traditional sand anchor and the box anchor (which many folks use on this forum) are notorious for getting hung up on the bottom on SML
        • swatguy
          • 1665
          • Midwest/ Northern IL
          • 2008 SANTE 210
          Hands down box/slide anchor. It’s only drawback is it’s a bit heavy. The thing sets instantaneously in almost any condition.
          https://www.iboats.com/shop/slide-an...QaAlDQEALw_wcB
          • GMLIII
            • May 2013
            • 2821
            I have lost 3 box anchors on this lake . The OP boats on the same lake as me. Box anchors are great anchors as I stated above and a very popular choice on this forum, but not the best anchor on SML . The Greenfield anchor is much better anchor choice on this particular lake
            • swatguy
              • 1665
              • 2008 SANTE 210
              I use ours on some pretty heavy timber lakes. Haven’t lost one. Guess my experience differs in that regard. As you mention tho you’re on the same lake as the op. Something to be said for that . I’ve been hung up hand full of times on those timber lakes , managed to get it free every time.....but I’ve also been hung up on those lakes with other styles as well over the years. So would say there isn’t any more risk involved in my areas regarding that. Ive lost (1) slide anchor in the Illinois River haven’t a clue what could've got it , but it did . Obviously your mileage is different.
              • GMLIII
                • May 2013
                • 2821
                Yeah understandable . Dont want to get into a best anchor battle but based on my long experience on this particular lake , the Greenfield has given me the best results over time
                • swatguy
                  • 1665
                  • 2008 SANTE 210
                  The bottom youre dealing with always determines the best anchor for your particular use. Its a case by case for sure
                  • LakesideRec
                    • Jul 2019
                    • 103
                    • Prior Lake, MN
                    • '15 Super Air Nautique 210 ''18 Bennington 25 spdxp '16 SeaDoo gtr 215 (2) '16 Yamaha SuperJet
                    I go with a hybrid style (not sure the name) here on Prior Lake which is typical of MN inland lakes. It has some mass, so most of the time in low winds, its just a lump on the bottom that I don't "set". Just thorw it over with a few degrees of scope, and its good enough for a calm day in party cove.. But in higher winds it can be set into looser bottoms (or more typically thickly-weeded bottoms) if deployed with enough scope. . I keep an old mushroom style and an extra 200' line on board as a backup.
                    • XBIGPUN66
                      • Oct 2012
                      • 479
                      • Lake Mendota
                      • WI
                      We use the Richter anchor
                      Ian S
                      • Nautiquehunter
                        • Jun 2008
                        • 2099
                        Go over to Bass Pro and pick up a Tie Down Engineering Hooker Quik-Set Anchor $15.99 - $36.99 add a 6' chain and a Anchor Buddy . You will never need more.
