Official Centurion Press Release:
Merced, CA (December 23, 2016) -There is a growing movement of people embracing the Supreme life with the only affordable premium towboat brand on the market. The nearly 24 foot Supreme S238 is leading the fastest growing surf and wake boat brand with segment defining performance, style, functionality and strength.
The 2017 S238 is a 23-foot 8-inch wake surfing towboat that makes it more fun to have fun for up to 16. The modified Deep-v Hull design, complemented by the QuickFill Ballast, Plug and Play Ballast and the available QuickSurf System, pushed by GM Marine Crusader Engines from PCM give you all the tools you need to power your fun. The Octo® Tower by Skylon towers above the rest with the style and strength. 2017 Supreme boats are also making waves with the new SeeTouch® Dash System, a completely new dash and touch screen that monitors and control almost every boat system, intuitively. All of this performance, style and functionality is supported by the strength of the vacuum infusion process for a towboat that has a build quality as remarkable as it’s quality of ownership. Visit your nearest Supreme boats dealer today and experience the only affordable premium towboat brand on the market.
High-fun Performance
Supreme’s Modified Deep-V Hull Design makes the funnest waves and wakes with the softest ride. This hull design is unique to Supreme boats displacing more water with less weight for amazing size and shape without compromising shock absorption on rough water. QuickFill Ballast leaves time for more fun with tooled-in ballast system that fills in two minutes and drains just as fast. The new standard Stinger Wake Plate orders prop turbulence to create cleaner wakes and waves without compromising push or kick. The large surface area of the Stinger also provides tight control of the boats running attitude, which improves wake shaping and rough water ride. Supreme QuickSurf moves World Class waves from side to side with a touch; in a Supreme boat weighted equally for comfortable level operation. All of this performance and fun is powered by GM Marine. Supreme boats now are optional with a GM Marine L96 6-liter 409 horsepower Crusader engine with 410 foot pounds of torque.
Cool Style
Supreme Boats is towering over the rest with style, strength and simplicity. The octagon-tubed Octo® Tower by Skylon offers strength and unique style to the 2017 S238. The Octo® has the strength of a compression latch activated overlock as well as the simplicity of weightless folding. Supreme’s new SportShield® windshield compliments the lines of the S238 and follows the design cues of the Octo® Tower with branded black wrinkle-coated a-pillars. Supreme gel coat graphics create the pride of reigning supreme even at the launch ramp. The cool look reflects Supreme fun performance and elevates pride of ownership. Supreme has created a new class of towboat with premium interior at a value price. The multiple colors and textures of Spradling’s Satin Matte Vinyl are sewn together with double and triple-stitched seams of GORE® TENARA® Thread included the hand-covered dash and throttle console. Colorizer your Supreme S238 online today.
Simply Works
2017 Supremes are making waves at the helm with a completely new dash and touch screen. The SeeTouch® Dash System has a high-end looks with a cool interface that provides control of almost every boat system. Power and adjust the standard ZerOff Speed Control. Command and monitor as much as 2,700 lbs of ballast. Execute QuickSurf to surf left or right and fine-tune those settings. Command and monitor the position of the Stinger Wake Plate. The SeeTouch® Dash System is as intuitive and easy to use as it is beautiful.
Strong Construction
Supremes boats are now built with the strength, precision and environmental responsibility of vacuum infusion. The S238 hull, floor, stringers and all small fiberglass parts are now creating using the vacuum infusion process (VIP). VIP creates a stronger, more consistent boat while drastically reducing emissions. The vacuum infusion process requires specific tooling, longer cycle times and higher consumable costs; however, Supreme Boats believes the strength, consistency and environmentally friendly benefits of VIP far outweigh the additional costs. This is the same “extra mile” attitude Supreme Boats takes with respect to trailers. The XHD Extreme Heavy Duty Trailers offers the strength of 7 gage steel HD tube frames with heavy duty axles and a 6” Patented “Pivot Hitch”. Trailers are sandblasted and then powder coated prior to accepting custom colors. The XHD offers a custom West Coast look with Frenched-in LED lighting and sleek fenders. The Supreme XHD Trailer also comes with a 5-year warranty.
Supreme S238 Specifications:
Length w/out Platform 23′ 8″
Beam 102″
Draft 32″
Weight 4,700 lbs
Fuel Capacity 63 gals
Seating Capacity 16
Ballast 1,100 lbs (STD) + 1,600 lbs (OPT) = 2,700 lbs
Tank Bow Ballast: 350 lbs STD
PNP Bow Ballast: 500 lbs OPT
PNP Rear Ballast: 1,100 lbs OPT
QuickFill Ballast: 750 lbs STD
Engine GM Marine EX3 by Crusader 1.72:1 GR (5 Year Warranty)
About Supreme Boats: World-class towboats that reign Supreme. Supreme boats are World Class performance, style, simplicity and strength built to help water sports fanatics reign supreme on the water at an extreme value. To learn how you can wake, surf and reign Supreme visit www.supremetowboats.com.
About Correct Craft: Celebrating 91 years of excellence in the marine industry, Correct Craft is a Florida-based company with global operations. The Correct Craft family includes Centurion, Nautique, Supreme, Bass Cat and Yar-Craft boat companies, Pleasurecraft Marine Engine Group, and Aktion Parks. For more information please visit www.correctcraft.com.
Cool Style
Simply Works
Strong Construction
Beam 102″
Draft 32″
Weight 4,700 lbs
Seating Capacity 16
