Hi all,
This is to remedy moisture buildup in the perfect pass gauge. If all else fails I’ll plunk down the cash for the stargazer model.
I used tuck tape to seal the back, the silicon spray to coat the board, and silica packets to make sure the interior of the gauge stays dry. Also I added some vents in my boat cover. The boat sits outside on occasion.
I attempted to superglue some of the packets but they seem pretty slick and wouldn’t take to the inside of the gauge.
Should be sealed uptight this tape does NOT let go. And the silica should hopefully do the trick.
Tuck Tape Construction Grade... https://www.amazon.com/dp/B01N6L7FK0...p_mob_ap_share
MG Chemicals - 422B-340G 422B... https://www.amazon.com/dp/B008O9YGQI...p_mob_ap_share
Dry & Dry 2 Gram [50 Packets] Premium Pure Silica Gel Packets Desiccant Dehumidifier - Food Safe Rechargeable Silica Gel Packs https://www.amazon.com/dp/B00DYLUWVO..._BJzsV2oolstOc
