Anyone Have Trouble With Helm Control Ballast Valves?
  • OldFart
    • Jun 2004
    • 401
    • South of North & East of West
    #136
    'Boy, that's a pretty broad statement. So "everytime" am improvement occurs (ie. graphics, tower, pcm,...) it is an admission of guilt? Not saying i disagree, just question the thought pattern.
    \"The voices aren\'t real...but they have some good ideas.\"
    • gotwake
      • 304
      • Mundelein, Il
      #137
      I too am worried, and looking already to upgrade. 30 hrs on my boat and one is sticking already. Please let us know what you find-
      The person who said \"Money can\'t buy happiness\" never rode behind an \"OLD\" 210.
      • OldFart
        • Jun 2004
        • 401
        #138
        RUMOR! RUMOR! RUMOR! some type of update came out of HQ. CC is testing the "black valves" from (i think) T-H Marine. Think someone's been reading PN. Skinautique, u behind this?
        • OldFart
          • Jun 2004
          • 401
          #139
          if this issue ever gets resolved, think of all the room PN will have for posts. It's like they ought to contribute some $$ to Cc to resolve it
          • FatBoy
            • Mar 2004
            • 756
            • Eastern North Carolina
            #140
            Of course not....But they said the helm controll valves would work, AND THEY DON'T. So they should fix them. You know, FIVE YEAR NO BULLS....T GARANTEE......
            Life is Short, Live it!
            http://www.teamcarolina.us/index.htm
            • ag4ever
              • 1180
              #141
              The difference between the graphics and the valves is simple. When a cosmetic change is made, there is no corrective measure made to the boat to make it perform like it SHOULD. When a part DOES NOT function as it was advertised or designed or told it would opperate, and then there is a change in a future model that corrects it, then YES there should be some responsability to correct the failed part.
              • FatBoy
                • Mar 2004
                • 756
                #142
                YEA, WHAT HE SAID.....
                • rustans
                  • 12
                  • Austin, TX
                  • 2003 Super Air Nautique 210 Team Edition
                  #143
                  Hey Jeff,
                  This morning I submitted an inquiry on the price for the Asco EF8210G095 valves through the Asco website (the EF being the explosion proof solenoid housing version). I received a reply that the list price is $196, and the sales rep sent me a list of distributors here in Texas to contact. I called the distributor in Austin (Rawson and Co), who didn't have any in stock, but have ordered them for me for $166.60 a piece. It's a bit pricey but oh well.
                  Jeff could you write up or email me installation instructions and pictures if you have any? Would be a big help.
                  Regards,
                  Rustan
                  • mike-d
                    • Aug 2003
                    • 236
                    #144
                    valves
                    for that price, you should of just bought the jabsco ballast pumps, three of them would of been better than ordering three of these valves, you could fill and empty out of the same inlet, etc. etc. etc. let us know when you get the valves, pictures etc set up.
                    mike
                      • 2908
                      #145
                      RE: valves
                      I think the easiest solution is to do like mike-d and hsmunoz have done and use the black T-H Marine RDV-2-DP direct replacement valves. Henry said it only took him 90 minutes to do the change and everything works. One of his new T-H valves had some excess flashing that he had to cut out with an exacto knife, another was a bit sticky so he cleaned and lubed all of them prior to installation. The arm also needs to be flipped the other way so their operation matches the open/closed labeling.
                      Since mine are now leaking lots of water I just ordered the new valves. My boat is new but the valve changeout is less work/less time then just getting my boat to my dealer so I am just going to do it myself.
                      Here is a link to the valves I ordered (about $60 including shipping):
                      LINK
                      Here is a link with a picture of the valves:
                      LINK
                        • 2908
                        #146
                        RE: valves
                        Here is a good replacement detail that hsmunoz sent me:
                        1. The T-H VALVES operate out of the package BACKWARDS of the stock
                        valves. Meaning when the cockpit actuator is in the "closed" position
                        the cable is extended, and the position of the T-H valve would be
                        "OPEN". a quick fix is to unscrew the actuation lever on the valve,
                        which is keyed by a square notch, and move it 90 degrees clockwise ,
                        or counter clockwise. Then replace the screw and make sure that when
                        the actuation arm is "fully extended" the vavle is closed.
                        2. The next thing is that the actuation arm has a small hole to feed
                        the cable into, this hole is too small and you will have to drill it
                        out not much I used 1/16 bit.
                        3. One of my valves has exessive flashing, inside , so I took it apart
                        and used an exacto blade to clean it up, in fact I did all three just
                        to make sure things were sano. Also, you will need to remove the screw
                        that is used to hold down the cable, and trim the plastic standoff
                        flush.
                        4. One valve was sticky, so I took it apart and lubed it with silicone
                        grease. Make sure all the valves upen and close easily.
                        5. Center ballast tank is a a breeze, under the ski locker, there is a
                        panel that is removed with two 7/16 bolts and 3 philips screws, remove
                        the old valve and replace with new, this is the confidence builder, 15
                        minutes tops!.
                        6, OK now for the port and starboard. I got to both from on top, no
                        need to pull up the floor. First the port, disconnect from the
                        thru-hull side, then pull it up for better access. Disconnect the
                        other side, then work the cable free, remove and replace. Same with
                        starboard side, only this one requires patience and some contorting.
                        What I did, was set the cockpit actuator to "OPEN" (Cable fully
                        retracted) , manually set the valve to full open (closed has alot more
                        slop to play with , but I wanted fully open to be perfect) then I
                        attached the metal part of the cable, and tighted it in place. Then
                        checked for proper cable travel.
                        7. Lastly DO NOT OVER TIGHTEN the steel hold down screw that tightens
                        the metal pinch clamp on the cable. I found out that this was a cause
                        of sticking cables. It needs to hold the cable in place , that's all.
                        If everything lines up, the plastic end of the cable (before the small
                        metal wire comes out) should be just before the first screw on the
                        valve.
                        and your done! in my opinion this is an absolute no brainer, if your
                        valves are leaking, which is inevidable (sp).
                        a quick side note,
                        I kept playing with the starboard valve because it was sticky , and it
                        turned out that the cables were kinked alittle due to the tie wraps
                        that the factory put on. These ty wraps, anchored the cables to the
                        thruhull's.I cut them off. what I did was pull off the 3/4 hoses that
                        connect to the valves, then snake the valve out, through the small
                        plastic hatch above the drain plug. Now you have the old valve (or the
                        new one) in your hands sitting in the boat. Then you can connect it up
                        , play with it, to make sure that it functions properly,and then snake
                        it back into the bilge. Then slip on the hoses , tighten , and done.
                        This is easier that my original "come in from above route)
                          • 2908
                          #147
                          RE: valves
                          Now that a good cheap solution is found, correct craft could consider a silent recall on these. In bulk purchase including shipping and labor it would only cost them about $100 per boat. Judging by all the activity on this thread it might be $100 well spent to keep their customers happy.
                          Just my $0.02
                          • OldFart
                            • Jun 2004
                            • 401
                            #148
                            RE: valves
                            ag4ever & fatboy, well said!
                            • bbc3
                              • Nov 2003
                              • 101
                              • Overland Park, KS
                              #149
                              TH Marine is the way to go. I did not switch the arm on them before the install, but the labeling is the least of my worries compared to the function...besides, I never actually crawl under the dash to look at what word the switch is pointing to. They work perfectly without a drop getting past them. When they are open they fill just as fast as the old ones (this is all in getting the cable anchored correctly so when the switch is open, the hole is completely open). Also, you can control how "sticky" the switches feel by how tightly you anchor the cable to the valve. Took me about 2 hrs, start to finish and clean up. Well worth your time.
                              If you don't want to wait for CC to cough up the cash, buy these valves and do it yourself...trust me you won't regret it.
                              • FatBoy
                                • Mar 2004
                                • 756
                                #150
                                I am not doing it myself. It's a matter of principle, they said they were supposed to work and by goodness they are going to make them work or I am going to pester the S#@t out of them till they do. Five year no bulls#@t guarantee.
