Does anyone know the cheapest way to make a flush pro? or some other cheap way to flush my engine? It is the pro boss gt-40 on a 99 pro air. And any pictures of install would be much appreciated. Thanks in advance.
RE: flush pro?
A simple T in the pickup line with a hose fitting works fine. I have used them for 30+ years without any issues. IMO, the simpler the better. Probably costs about $20 in fittings at the hardware store, I use plastic.
RE: flush pro?
What I've always done is connect a 3' section of clear flexible PVC hose to the hull side of the transmission cooler and drop the other end of the hose in 5 gallon bucket fed by a garden hose. Put a ball valve on the garden hose, fill the bucket about 3/4 full, then crank it up. Cost is less than $10 and it only takes a few minutes to hook up. For a more permanent setup, the t-fitting Mikeski mentioned would probably work like a charm.1998 Ski Nautique (Red/Silver Cloud), GT-40, Perfect Pass Stargazer 8.0z (Zbox), Acme #422, Tunable Rudder.
Re: RE: flush pro?
Same here. My setup was posted in your response on CCFan, but here it is again. ~$15 in parts from Home Depot:Originally posted by MikeskiA simple T in the pickup line with a hose fitting works fine. I have used them for 30+ years without any issues. IMO, the simpler the better. Probably costs about $20 in fittings at the hardware store, I use plastic.
-1" Tee
-NPT to GHT adapter
-garden hose valve
-2 hose clamps
1990 Ski Nautique
NWCT
RE: Re: RE: flush pro?
Thanks guys! i appreciate the help. Looks like ill be going to home depot tonight.
