red hoses not connected
  • hdultra
    • May 2007
    • 121
    • Alabama
    I have a 2004 210 with the zr6 and I was looking around the engine and found 2 red hoses not connected. They appear to be around 1/2 id hoses and are right under what I believe is the thermostat. Right above them I found were they might plug in but there is a u shape hose that doubles back into the believed thermostat. I have the heater option however it does not really blow out hot air so I was wondering if this could be the problem or is that for the optional shower. I can try to get some pics if it would help.
    Thanks
    2010 SANTE 210
    2004 SANTE 210
    1986 2001
    1989 2001
    1992 SNOB
    1987 2001
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    RE: red hoses not connected
    Sounds like your heater hoses are not hooked up.
    Chris
    • Sinkoumn
      • Jun 2006
      • 578
      • MPLS - St. Paul, MN
      • Super Sport Nautique
      Get a pic up for sure, but it does sound like a bypassed heater line
      [url=http://www.neustonboards.com][i][color=Blue][size=4]Neuston Boards[/size][/color][/i][/url]
      [size=4][i][color=green]Nautiques[/color][/i][/size]
      • Hollywood
        • Sep 2003
        • 1930
        • WIIL
        I'll go with heater hoses disconnected after a winterization as well. I thought I heard that there was no (factory) shower option on the ZR6?, so that's gotta be for the heater.
        • SuperAir
          • 73
          • Texas
          I concur with other posters that the previous owner disconnected the heater hoses. I did this on my 02 210 after I had the replace the heater core after two years. I rarely used the heater anyway so I ended up looping the heater connection and saving me from having to replace the heater core every few years.
          • AuMDLST
            • Apr 2007
            • 870
            • Orlando, FL (Butler Chain)
            Most likely heater hoses - I helped a neighbor remove bad heater and that is similar description - South East Correct Craft said those heaters tend to go out every two to three years - no need to replace that option living in Florida
            2006 SANTE 210 (Pending Sale)
            2005 206 TE (Previous)
            • hdultra
              • May 2007
              • 121
              • Alabama
              I wasn't able to get a pic today but if it is the heater hose and I get a new heater core how much coolant do y'all think I will have to add.
              Thanks
              2010 SANTE 210
              2004 SANTE 210
              1986 2001
              1989 2001
              1992 SNOB
              1987 2001
              • Hollywood
                • Sep 2003
                • 1930
                • WIIL
                None it uses the water you're sucking up out of the lake after it's gone through the block. What makes you think you need a new heater core?
                • Laptom
                  • Oct 2003
                  • 876
                  • Eindhoven, Netherlands
                  I'm not sure Hollywood, but I thought the ZR6 has standard a closed cooling system and the heater core was connected to the closed cooling system. You'll need to add some coolant when installing a heater core.
                  But like Hollywood asked, why do you nee a new core?
                  • nautique95
                    • Apr 2005
                    • 420
                    • Michigan
                    • 1987 SN 2001 1994 SN 1995 Signature Edition 2005 206 Air Limited 2007 SV211 Team
                    I bet SuperAir hit it on the head, the previous owner probably had a leak in the core and just bypassed it instead of replacing it, especially if there is a bypass loop on it now.
                    • Hollywood
                      • Sep 2003
                      • 1930
                      • WIIL
                      ****it now I forgot he had the ZR6. I think this guy got all the advice he needs, we're all just repeating ourselves at this point.
