so have had the boat running very well after replacing the distributor and having the carb completely rebuilt.
we've been chasing a forward idle forever, and it still is not corrected 100% of the time.
sometimes the engine runs perfect in all categories, and other (like just now)it will sputter and stall in forward idle.
had it out for a ski this morning and no problems.
just went out for a cruise and I could tell it wasn't running right. pulled it back to neutral and then into gear and yep... it stalled out.
so I opened the hatch and started it up to tune the idle speed screw. didn't help... I backed it off almost completely and the idle would hang high. then I got it into gear by throwing it into gear and past idle. got up to speed and gave it some good gas. then it stalled out at speed, which it has never really done before, at least not since rebuilding the carb and new dist.
when it stalled I opened the hatch and could hear a hissing sound coming from the alternator side of the motor, from the top of the engine by the carb or valve cover, riser area. couldn't pin point it.
I pulled the vacume hose off the carb and tried to suck and blow. didn't seem to do anything. put it back on and went to the idle speed screw...
so I backed the idle screw right out after starting it up (no problem starting it) until it almost died and turned it in until it wouldn't stall. put it in gear and turned it in 1/4 turn. then tested it by putting it in neutral then forward and repeat.
was perfect.
then gave it nearly wot and it ran flawlessly. took it back to the dock. shut it down. start, neutral, forward, reverse. no problems and no hissing like before.
I'm completely stumped. how does it run flawlessly one minute and horribly the next without really doing anything?
was perfect.
