1992 SN
The key ignition sticks to the right when cranking which grinds the starter after the motor cranks if not manually moved back slightly to the left.
Secondly, the key has become incresaingly difficult to even turn to start if not pushed in hard and hitting the "magical" spot.
How hard is it to replace the key ignition? I'm guessing it's just a matter of unscrewing, replacing and re-connecting to the wiring on the back. Am I correct?
