There is no question in my mind that you can get away with running your boat without water for a short time. You also have a possibility of not damaging your impeller. There is also a possibility that you could damage your impeller. If you have minor damage on your impeller, there is a very real possibility it could fail completely when you are away from the relative safety of a launch ramp or dock.
The original question that started this post is as follows:
" Is it bad to start the engine when the boat is not in the water? I usually start it for less than a minute just to insure that once on the water, the motor will start. I don't put it in gear.. just idle for about 30 seconds.. is that bad?"
The answer to that question is Yes, it is bad. it could cause your engine to fail to run properly (limp mode) when you are away from the launch ramp.
Do you want to be out in the middle of some lake , in limp mode, when a thunderstorm comes up?
Would you rather have do drag you boat back on the trailer with the winch if the engine did not start?
I have not done a statistical study on this, but I would guess that there are more water pump failures caused by running the engine with out water than there no starts caused by an engine failure. Please note, I do not consider a dead battery an engine failure.
Running your engine without cooling water can possibility cause your impeller to fail at a very inconvenient time, some times even after several successful trips out with no apparent problems.
Once again, do not run your engine without cooling water, ever.
