Ok. I put a new motor in a couple of weeks ago. Ran it in the driveway for about 20 minutes about 2 weeks ago. Then went on vacation. So now I am back and was going to run it to break the motor in. Well the fuel pumps dont have power.
Both the relays are good. They both click and i have tested power coming out of them. plus I went ahead and replaced them too.
I jumpered the neutral safety switch so that aint it.
I tried the safety lanyard. That was not it.
There is definetly a short between the relays and the pump themselves. I ran direct power to each pump and they both run.
When the power leaves the relay where does it go next? It does not appear to be a direct shot to the pumps. Is there another switch that has to be made to make the pumps run besides the nuetral safety and the safety lanyard?
I am thinking I have a oxidized connection or a short. Any suggestions? I think I am going to start taking every wire off and start cleaning them. I also cleaned all the battery connections. The negatives and the positives.
Thanks to anyone who can help me with this problem. The wires dissappear into the harness so its a pain to trace out. :?:
