Wiring the Tower Light
  • mcbridek
    • 241
    • Raleigh, NC, Lake Gaston NC
    • 06 Ski Nautique 196 SE (2010 - Current) 99 Sport Nautique / GT 40 / FCT (2005 - 2009)
    Anyone know the best way to wire connect the tower light ? 99 Sport Nautuque / New Dim Tower
    06 Ski Nautique 196 SE (2010)
  • Onevw2go
    • 179
    • Wisconsin
    RE: Wiring the Tower Light
    I don't know if this is the Best or correct way, but I wired mine directly to the battery with some Heavy duty wire, I used a Ford starter relay in that setup, with an unused button in the dash pad(heater button) to activate the relay. make sence?? if you want I can post some pics. let me know on the forum.
    • mcbridek
      • 241
      Onevw2go - got it. I was thinking if I could figure out which wire ran to the rear post light, then I could connect into that wire and it would then be activated off the navigation light dash button. But when i started looking at the wires that ran to the rear of the boat, there was alot of wires, at least 10 under the starboard gunnel
      • surroundsound64
        • Jul 2005
        • 2148
        • Longview, TX
        • 2026 S23 1981 Ski Nautique
        I posted once... not sure what happened.
        Mine is wired to the same switch as the other nav lights. Wayne at NDT did it.
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2011 Sport 200V
        Sold - 2000 SAN
        • 1999Sport
          • Aug 2006
          • 75
          • Livermore, CA
          Just trace the wires that come from light at the front of the bow back to your dash...pick up some wire taps...and tap into those wires. Then, when you turn on your navigation lights at the dash, you only have to hit one button. I did this in 5 minutes during a houseboat trip for night use to be legal.
          • Andrew
            • Aug 2005
            • 891
            • Tuscaloosa, AL
            it all depends on what power lights u r running and how many there are.... u don't wanna put too many lights on the nav circuit. the wiring for the navigational lights is not meant to carry alot of extra stuff
            • 1999Sport
              • Aug 2006
              • 75
              • Livermore, CA
              Re: RE: Wiring the Tower Light
              I thought we are talking about the little light on top of the tower, am I correct? And I would assume without the pole light plugged into the back of the boat...this would be ok....since it's only powering two lights still
              • Onevw2go
                • 179
                • Wisconsin
                RE: Re: RE: Wiring the Tower Light
                sorry, maybe it was my misunderstanding. I thought we were talking about a light bar atop the tower. I am running 6- 55watt light on my tower, and the wiring i referenced was to run that.
                • Andrew
                  • Aug 2005
                  • 891
                  • Tuscaloosa, AL
                  yeah so, i have no idea what we are talkin about lol
                  • surroundsound64
                    • Jul 2005
                    • 2148
                    • Longview, TX
                    That was my understanding as well... if you are talking about a light bar, don't do what we said to do!
                    2018 SAN 230
                    1981 Ski Nautique
                    Sold - 2000 SAN
                    • mcbridek
                      • 241
                      Yes, this is the small light on the NDT tower. Ok so I should see two wires that go to the front light and just splice (not sure what tap is) into each (have to look, boat is not at my house). On the rear lamp, I located a single gray wire that goes to the lamp and it looks like the wire then travels from the light into a panel that has about 10 wires. I am guessing that is the negative. I'll look for the front light, may be simplier.
                      • surroundsound64
                        • Jul 2005
                        • 2148
                        • Longview, TX
                        Anyone of the nav light wires should work. Splice is the same as tap.
                        2018 SAN 230
                        1981 Ski Nautique
                        Sold - 2000 SAN
                        • alalor1
                          • May 2006
                          • 64
                          • Bryan, TX
                          I would not connect it to the bow light, because then it would not work as anchor light. Remember that you have to have a 360 degree white light (to be seen within a 2 mile radius) when you are not under power. Then the bow light must be one when you are under power. If you wire it to the bow light, you can't use the anchor button any more.
                          So, I would look again and connect it to the stern light, so you can use it as anchor light too when you want to relax, work on something or just anchor.
                          • Andrew
                            • Aug 2005
                            • 891
                            • Tuscaloosa, AL
                            is there any problem (legally) with having the anchor light on while underway?
