Boat just doesn't want to wake up from winter???????
  • MNSuperAir
    • Sep 2005
    • 591
    • St Paul
    • 2016 SAN 210
    The maiden voyage a few weeks ago I noticed the PP and blower both didn't work and the boat seemed sluggish. I replaced the servo to fix the PP but my boat is still slow out of the hole. Last fall during winterization I replaced the fuel filter and fogged the cylinders. I am planning on replacing the cap and rotor tomorrow. Anyone have any other ideas as to what might be wrong? Still have the same tank of gas in the boat. Throttle is going to full throttle.
    Thanks in advance
    2016 SAN 210
    2006 SANTE sold
    2001 SAN - sold
    1991 Sport Nautique - sold
  • Sinkoumn
    • Jun 2006
    • 578
    • MPLS - St. Paul, MN
    • Super Sport Nautique
    RE: Boat just doesn
    The gas is old, I had the same problem last year. We tried to ride the first day out but the boat lagged and felt like it had no energy. Filled up the tank with Premium (about 5 gals or so) and she was back to ripping!
    [url=http://www.neustonboards.com][i][color=Blue][size=4]Neuston Boards[/size][/color][/i][/url]
    [size=4][i][color=green]Nautiques[/color][/i][/size]
    • krs0394
      • Jan 2006
      • 170
      • Sturgis, MI
      RE: Boat just doesn
      Check the fuel filter to make sure the gas did not gel and plug it up.
      1973 CC Skier
      1989 SN 2001
      2002 SN 196
      2005 216 Limited
      • MNSuperAir
        • Sep 2005
        • 591
        • St Paul
        • 2016 SAN 210
        RE: Boat just doesn
        Just replaced the gas, cap and rotor, and checked the firing order and still no luck. It start and idles great. It sounds like it has plenty of power if you rev it up in nuetral but under load it has no power. An example, I have an 856 prop and the boat has a slow hole shot. Last year that prop would rip your hands off.
        Thanks krs, I will check that. I am also going to replace the plugs. Need to do a search to see what plugs to buy. I thought they were autolite 864's but I will check.
        2016 SAN 210
        2006 SANTE sold
        2001 SAN - sold
        • krs0394
          • Jan 2006
          • 170
          • Sturgis, MI
          RE: Boat just doesn
          The other thing you might want to try is a bunch of carb cleaner. If the fogger gumed up the floats and seats it could cause a sluggish start. Did you check the accelerator pump??? I have had those things dry out over the winter months and not pump enough fuel into the carb at fast acceleration.
          1973 CC Skier
          1989 SN 2001
          2002 SN 196
          2005 216 Limited
          • MNSuperAir
            • Sep 2005
            • 591
            • St Paul
            • 2016 SAN 210
            RE: Boat just doesn
            I only sprayed the fogging oil in each cylinder not through the intake. I was told that fogging oil through the intake on a gt-40 is a bad thing. What and where is an acelerator pump. Sounds like blinker fluid to me. Do you have a pic that you could describe how to check it? Thanks
            2016 SAN 210
            2006 SANTE sold
            2001 SAN - sold
            • krs0394
              • Jan 2006
              • 170
              • Sturgis, MI
              RE: Boat just doesn
              Not sure on your carb, but on my old holley there was a small accelorator pump that when you pushed the throttle down it shot an extra amount of fuel into the barrels. If it is there, it would be a small push rod on top of the carb that gets depressed when you open the carb up. Should be close to the fuel intake. Sorry I have no pics, none of my current boats are carbed. Check out this link http://www.chevyhiperformance.com/ho.../photo_02.html
              1973 CC Skier
              1989 SN 2001
              2002 SN 196
              2005 216 Limited
              • MNSuperAir
                • Sep 2005
                • 591
                • St Paul
                • 2016 SAN 210
                RE: Boat just doesn
                No carb here either. I think I know waht part you are talking about though. It is a holly only thing, right?
                2016 SAN 210
                2006 SANTE sold
                2001 SAN - sold
                • H2O
                  • Jul 2006
                  • 247
                  RE: Boat just doesn
                  I would go over the Perfect Pass system with a fine tooth comb. If you had problems with it not working then replaced the servo motor, I bet it is still a problem. Inspect the PP throttle cable and be certain it operates fully with PP on or off and very smoothly.
                  • krs0394
                    • Jan 2006
                    • 170
                    • Sturgis, MI
                    Re: RE: Boat just doesn
                    I do believe so
                    1973 CC Skier
                    1989 SN 2001
                    2002 SN 196
                    2005 216 Limited
                    • MNSuperAir
                      • Sep 2005
                      • 591
                      • St Paul
                      • 2016 SAN 210
                      I do believe so
                      I believe it was called a power valve
                      2016 SAN 210
                      2006 SANTE sold
                      2001 SAN - sold
                      • coloradonautique
                        • Sep 2006
                        • 98
                        • Denver, Colorado
                        • 2001 AN 1990 SNCB
                        RE: Re: RE: Boat just doesn
                        I think the power valve was something else. I remember replacing it when rebuilding the holley carb on my '91. I believe the item in question is indeed called an accelerating pump. It is supposed to squirt a extra dose of gas into the carb when the throttle is pressed forward. Supposedly this helps remove the hesitation and smooth out the transition from idle to power.
                        ___________________
                        2001 Air <-- New boat
                        1991 Ski <-- Old boat
                        Denver, CO
