As posted in my cleaning thread, I acquired 2 brand new marine rv deep cycle batteries. I had planned on adding those to my existing batteries. I currently do not have the cash to do an isolator setup at them moment. However, I will eventually do a hellroaring or similar setup.
My question....
Will I fry my alternator by basically hooking up the four batteries in parallel? I have the standard perko switch. My plan was to leave the stock battery in the stern to power the engine only. The two new batteries will be wired in parallel to the bow battery.
The two new ones are slightly different. Same CCA as the others, just new and a different interstate model line.
Is there any way to do this and be safe? I will probably plan on running this setup for a few months to build my funds back up. I will redo the power delivery system when I buy new amps and a sub.
Thanks!
My question....
Thanks!
