Ok due to a bad impeller pump I overheated my GT40 the first time out this year. Since there was no water in the engine due to winterization the temp gauge never read hot. I ran it in idle for about 10-12 minutes. I was getting ready to fill my ballast when I noticed it was hot. I immediately shut it down. I used my ballast pump to fill the engine with water which cooled it down a bit and allowed me to get back to my lift.
I fixed the pump and notice a shake in the boat when accelerating which lead me to believe I had an engine problem due to the overheat. I ran a compression test and they were all 130-135 except cylinder number 7 which was like 90-92. I figure I have a bad head gasket.
So far I have torn the motor down to the block and have the heads off. I didn't notice a tear or anything in the head gasket but I am assuming there must have been a slight leak and since I have only ran it about 10 minutes after installing the new pump that I caught the problem early.
I have ordered a new valve grind gasket set from Skidim which has head, intake, exhaust, ect gaskets. I also order the upper intake gasket. The kit has valve stem seals which I also plan to replace along with the exhaust hoses (didn't look bad but got a little hard) and riser gaskets. New thermostat, dist cap and rotor.
I have two questions-
1- anything else I should look to replace while I have it apart?The engine only has about 300 hours on it.
2- does it seem reasonable that it was the head gasket causing low compression or should I look for some other cause. The cylinder looks good no signs of scoring the head seemed to look ok too. My hope is that it was just the gasket, but again I couldn't see any real tear, but the gasket didn't come off clean either the material was kind of broken down and sticking to the block and the head. The stainless rings were all in place throughout the gasket.
Stan
Stan
