I didn't want to hijack a previous thread on top speed, but had a question myself. I have a DD sport nautique w/ GT40 01'. I just changed out the digital gauges to Faria analogs and am will be finalizing my calibrations. Just curious what other DD sport or air GT40 owners were seeing as a top speed and at what RPM? Thanks for the help.
RE: 2001 Sport or Air DD Top End
We have an 01 Air as well, but I couldn't tell you the top speed or RPMs off the top of my head. For calibrating, I recommend that you find a portable GPS unit to help with that.2001 Air Nautique
or a slalom course and use the time tables. Yellow_Flash_Colorz:___________________
2001 Air <-- New boat
1991 Ski <-- Old boat
Denver, CO
Re: RE: 2001 Sport or Air DD Top End
That assumption isnt quite right. My dad's 196 can turn the same prop (Acme 422) 4900 RPM, but his top end speed is only 46-47 according to GPS.Originally posted by RickI have a 2000SN I figure 1 mph per 100 RPM. my top is 48 mph at 4800 RPM thats with a 12.5 X 15.5 prop.1990 Ski Nautique
NWCT
RE: Re: RE: 2001 Sport or Air DD Top End
Hey guys, Is that ACME 422 12.5 x 15.5 the stock prop for the SN or did you guys change from stock setup? If it wasn't stock, what is stock for that boat and did you notice a big improvement with the new prop.
The reason I ask is because I have a 13x16 4blade OJ Legend on my 2001 AN at Denver altitude and the performance is lacking. Considering a change to a 12.5 x15.5 ACME 4blade or a 12.5x15 ACME 3 blade (highly recommended by ACME rep).
Any thoughts or experiences? Half an inch in diameter and pitch doesn't seem like a lot of improvement. Does the CNC machining really make a huge difference? I am assuming the Legend was not CNC machined originally.
Thanks.___________________
Denver, CO
Not sure how many people have tried all 3 of those props (Legend, 470 and 422), but I have.
The 470 will turn 200 more RPM and outperforms the 422 even on a lighter, unweighted boat thats closer to sealevel.
Yes, you will notice a big improvement going to either Acme from the Legend- but the 470 is the better prop. If you search Ive shared my impressions (seat of the pants and speed/RPM numbers) before.1990 Ski Nautique
NWCT
LakeaustinSN - As others have stated, I went throught the same upgrade and used a GPS to re-calibrate. For what it's worth, the GPS seemed to vary from run to run, so I ended up making multiple passes in both directions then adjusted my speedo to the average. I installed a PP shortly after, and the calibrated speedo runs very close to the PP.
Coloradonautique - I ran the original OJ prop for many years, then switched to 422 after dinging the OJ. Unfortunately, I did the swap between seasons - at the same time I did the Faria gauge replacement and added PP - so I didn't get good back to back runs, and I don't have speed data. The 422 feels good - maybe slightly quicker out of the hole and smoother - but not so much that it alone would take care of your issue (doggy out of the hole). The 470 sounds like a good swap - but I was waiting for you to get one and post your results!!!
Jeff
Jeff,
I am working on a trade for a 470. I will let you know if it happens and whether it makes a big difference. I did not get to clock any times or collect data on the old prop so it will be a seat of the pants (or more accurately "deep water pull") comparison.
Later,
Lorin___________________
Denver, CO
