The last two times I've taken the boat out I've ran into a problem that I haven't read on the forums on here or correctcraftfan.com.
So time to ask you gurus for as much help as possible...
The first few times I start the boat...it stays on for about two second and then dies..unless I keep the idle up for a good 30 seconds to 1 minute. After I do this...the boat has no problem starting again for the rest of the day. Any ideas?
I just recently changed the oil and tranny fluids before the last time out.
Now...the low idle problem....if the boat isn't kept going at a little faster idle then its lowest point...it will die...when attempting to pick up a rider out of the water, you have to dump on the throttle to get past this point..and once its gets going, its fine. If you back off the throttle to a nuetral position ( so the rider can grab the rope/ handle) and then re engage in gear...it will kill itself.
When in neutral the boat idles at around 700 rpm
There is also what almost sounds to be a chatter coming from the transmission, but this only happens at certain times...when some friends and I were out cruising this past time, the noise would go away, and then come back. Any ideas? I've read that it could possibly be the damper plate, as this noise only happens when the transmission is engaged in either fwd or reverse, and never when in neutral.
Any help would be greatly appreciated. I am mechanically inclined...so working on these types of things aren't a problem for me...just not sure where to really start on this one.
