Hi guys.
We have a 2003 SAN. with a pcm excalibuer engine. I noticed we have a small amount of oil in the bildge... after feeling around the base of the oil pan(sump) it looks like it is acutally leaking from the drain hose at the connection, there doesnt seem to be a hose clamp on there. anyway hopefully putting a hose clamp on will fix our leak.
I'm curious though if anyone has changed the sump gasket on a SAN before? did you have to remove the engine ? or is there enough clearance in the bildge to drop the sump and avoid lifting the engine out.
Cheers.
Cheers.
