As the part owner (I help with $ and labor) with my daughter and her husband on this boat, I need a little help. It has the GT-40. The engine over heated and will soon be running again with one new head and a valve job on the other one. The dealer says to replace the muffler (for $800), as they go bad when this old and that is what caused it to overheat. Is there any way to check it out? Is there anything inside the muffler beside some baffles? That is only an assumption on my part. Without a better suggestion, I'm about to cut a 2" hole into the side or top and look inside. If everything is ok, then just fiberglass the piece back into place. Any other ideas?
Thanks
Thanks
