I have a '97 Super Sport, and had some freeze damage last year.
(tried to extend season too far obviously)
I had a couple of lamps on the block, and that appears to have had
no damage. I initially thought it was just one exhaust manifold
that cracked, but after replacing that and firing it up, found that
the intake manifold had cracked around the thermostat housing.
(it also pushed out the bronze plugs in both heads.)
I drained it all again and ran it for a few seconds to make sure
there was no water in the cylinders, then pulled the plugs and
sprayed a bunch of oil in the cylinders. It still turns freely
by hand.
My current thinking is to replace the lower intake manifold, put
in new bronze plugs, and see if everything is ok. Is there anything
else I should look for, or anything that is certain to be damaged?
skidim doesn't show a manifold on their site, nor have I found
the exact part online elsewhere. I emailed skidim to see if they
have it, and how much it would be. I did find an offroad-only
aluminum lower manifold, but didn't know if it was an exact fit,
and if the aluminum would be a problem w/ galvanic corrosion.
http://www.fordracingparts.com/parts...tKeyField=8764
Any insight or info based on similiar experience is welcome.
thanks,
tim
by hand.
thanks,
tim
