PCM 351
  • licka77
    • Dec 2006
    • 5
    PCM 351
    How do you tell which model engine youve got- Im told I have a 1995 PCM 310 HP- Is there some sought of markings that distinguish the 310HP?
  • ffmedic74
    • 835
    • Lexington, KY
    RE: PCM 351
    If you have a carb it should be 240 or 260. If you have a GT40 injection it should be 310hp.
    • skinautique
      • 1749
      • Colorado
      RE: PCM 351
      what does the decal on the black plastic decal say? Is there a carburetor under the plastic piece?
      • TRBenj
        • May 2005
        • 1683
        • NWCT
        Re: RE: PCM 351
        Carb'd ProBoss motors (which had GT40 heads) were rated at 285-300 hp.
        1990 Ski Nautique
        NWCT
        • ryanandrews
          • 233
          • chippewa lake ohio
          i have a 94 cb tique w/ the 351 w 5.8 h.o. pro tec motor...i was told by people at pcm and correct craft and dealers that the horsepower was 300...........i know the boat flys! :mrgreen:
          • licka77
            • Dec 2006
            • 5
            PLPPRL10OPTI This is the serial number I have on the engine- can anyone decipher?
            Which engine I have?
            • TRBenj
              • May 2005
              • 1683
              • NWCT
              I believe the 3rd digit indicates that you have the GT40 heads. From memory, my 240hp motor started with PLDxxx. PCM or SkiDIM could tell you exactly what you have from the serial number. Im not sure if its a Proboss (carb), Proski (TBI) or GT40 (MPI). The carb and TBI look similar, but the GT40 looks quite different. All 3 were available in 1995.
              ProBoss:
              ProSki:
              GT40:
              1990 Ski Nautique
              NWCT
