Pulley squeak on a 2018 SN
  • jmo
    • Mar 2006
    • 734
    • MA
    Hi All,
    on my 2018 SN 200 (H6 motor) I have a pulley or accessory squeaking at idle after the boat is warmed up. 620 hours, regular maintenance performed, I replaced the serpentine belt already and that didn’t fix it. It sounds like it’s coming from the alternator but I can’t be sure?
    any ideas? I see in the manual to check the alignment of the pulleys, how do you that?
    thanks,
    JMO
    2018 Ski Nautique 200 TE, H6
  • SatherG230
    • May 2018
    • 92
    • MN
    • 2012 SANTE 230 w/ NSS
    I am not familiar with your engine's setup, but did you check the idler / tensioner pulley when you had the serpentine belt off? I usually check mine when I have the belt off to check / service the water pump impeller.
    • jmo
      • Mar 2006
      • 734
      • MA
      Thanks - I just took the belt off to check each pulley by hand. Here is what I found:
      1. The idler pulley closest to the RWP has a definite wobble but no squeak.
      2. The pulley for the alternator definitely squeaks, but no wobble.
      i hope the pulley/bearing for the alternator can be swapped out without replacing the alternator itself? Anyone know?
      • jmo
        • Mar 2006
        • 734
        • MA
        Here is a video clip of the alternator
        • SatherG230
          • May 2018
          • 92
          • MN
          I cannot open the video, but it sounds like you have two issues. I would definitely replace the wobbling tensioner assembly. The bearings in the alternator (both front and rear) can be replaced by a qualified shop if you have one around, but a new alternator means less downtime. I would start by replacing the tensioner assembly, as it should not wobble. See if that cures your problem.
